Originally posted by Mushu YAY!! Thank you so much for the quick answers. Looking forward to finding a good deal on that puppy...amazon days coming up soon. I've been missing taking pictures and this body should make beautiful pics. Wonder how my APS-C lenses will do, does it give a black halo or something? Guess I need to start reading up on it...
EDIT: I also have an old K2000 and wonder if it also suffers from that. I think it still works but haven't used it in close to a decade.
Your K200D might still work fine, but after such a length of time, it probably has lost its internal info charge-up so you'd need to reset time and date whenever changing batteries. Still a good camera, and some users like the colors from the CCD sensor.... but not in the same league in some respects as the more recent models. It employs the better solenoid part from the previous supplier, which could be transferred to your K30, for a permanent fix. As others have suggested, whether you would benefit from the particular advantages the K-1 II would offer over a better APS-C body depends on your shooting needs. My own are varied enough so both serve me well depending on the occasion and circumstance.
As to the K-1 II, it is one awesome camera. But with the larger full-frame (FF) sensor, you are getting into a whole other experience in photography, as the lenses you are accustomed to using have a narrower angle or field-of-view (FOV) at a given focal length (FL) on APS-C bodies than they would on a FF body. For example, a 50mm lens would provide a moderate telephoto FOV on your cameras with the smaller APS-C sensors, but would present a "normal" angle- neither tele nor wide on a FF camera, including a 35mm film body. In this case, a possible practical advantage for APS-C, as the 50mm lens becomes near to being a poor-man's FA 77mm Limited on a FF body- similar image size in the viewfinder (VF), which is within the ideal FL range for portraits, for instance. APS-C can thus also offer a big savings In expense, size, and weight when dealing with longer telephoto needs. So as to which of my setups I will be using on a particular occasion depends what kind of subject matter I'll be shooting and distance, the circumstances of traveling around where compact carrying will be paramount, etc. Both FF and APS-C have their distinct advantages. Sometimes they do overlap in terms of practical usage, as to FL and FOV vs. size. When this is the case, the 36mp K-1 II will have the image quality advantage, though my KP with a likewise quality lens will be close. But coming from a K30, you would very likely find some major improvements in imaging, and certainly in higher ISO performance.
I am an old 35mm film shooter, including many years with Pentax gear. When I finally got into digital, my first DSLR was a Pentax model, and have been upgrading ever since (including the K200D). Until the coming of the K-1, all Pentax DSLR models have been APS-C. So from experience, I became aware of the differences between FF and APS-C very quickly, having come from the FF end (as is 35mm film).
As to your APS-C lenses, most would only be usable in crop mode on the K-1 II, which would be at a resolution and FOV quite similar to that of your K30. In FF mode, most would present significant darkening-vignetting in corners and at edges of the frame. But not all DA lenses do this, as some are FF compatible. It would be of interest to us if you would post the lenses you own, so we could give you some insight here.
In any case, I would strongly advise upon purchasing the K-1 II, that you get the deal with the DFA 28-105mm "kit" lens included, as I did. 28mm on the FF K-1 II provides substantial wide angle, where on APS-C bodies, 28mm would provide no WA at all. This lens is far above the usual "kit" lens. The quality of this lens is absolutely outstanding, and a bargain at its normal non-kit price, but prepackaged with the K-1 II you get about $100 off for the lens. The usual price of this lens alone is around $500 US. I got mine through B&H, with whom I've done business for many years. In case you are in the USA, I'd suggest you take a look. I just checked, and they still offer the same deal, which includes throwing in some useful accessories. Be sure to look through all the Pentax DSLR listings to find the deal. Although I have some very fine old lenses from my 35mm film use, this way I reasoned, I'd have a lens offering WR to go with the WR construction of the camera, as well as excellent, quiet, fast AF performance. I was not prepared for the very fine imaging quality this lens provides!
Hopefully, you would not use this camera with the mode dial set to the green "auto", which would disable controls, leaving complete control to the camera and denying all access to controls and adjustments. For fully automated exposure setting, use the "P" Program mode instead, which allows all access, including the exclusive Pentax Hyper System. When in P mode, and the camera sets a shutter speed or aperture not to your liking, you can instantly change to your preference simply by using the front finger or rear thumb dials, and the camera will instantly obey (if lighting allows at the ISO setting), switching to Av or Tv operation without having to first change the mode dial to Av to Tv before making your selection. A touch of the green button instantly restores full P operation. Very fast and efficient. I believe the K30 has this feature, requiring both front and rear dials, but the K200D does not. It is an old, very useful Pentax design.
If you often or sometimes like to shoot highest-quality JPEG images right out of the camera, for superior results, it is best to go into the Custom Image menus to adjust sharpening. On the K-1 II, there is direct access via the button right of the ok button. Then these 4 surrounding buttons serve for navigation. With the K-1 II, as is common for upper-level designs, native sharpening is conservative as many users will post-process images to their liking. As to the K-1 II, I find this is to be even true of the most often-used "Bright" Custom Image category, in which sharpening by default is already up by +1, so I increase that up one more notch to +2. Then as always, I also implement "Fine Sharpening" as well, using the rear thumb dial. You will then get really great results for right out of camera imaging.
