Originally posted by Rob Gravelotte Also, I'll probably buy a new lens, I love taking pictures in low light, and what I have, apart from the tamron 90mm macro, is not that good.
Money...
Again, thank you, you have inspired me to put in some effort!
Glad to hear you got your K200D working. Nothing wrong with keeping it as backup, even if buying an updated model. You'd not get much for selling it. Its top ISO setting is only 1600. Even at that setting, performance is marginal- just barely "ok". For low light shooting, and much more, I'd say save up to get a low-use, perfect copy of the much-advanced KP. With a KP, ISO 1600 and much higher is a breeze for quality imaging. It is simply in a different league. Pro-level build and great controls- fast, comprehensive, and convenient. It is the advanced photographer's compact model, and very unique in this concept. It is also the only DSLR designed to compete as a compact model against the high-end mirrorless APS-C offerings of other brands, and does so with features (lots of them) and control advantages they do not have. Like them, it is not designed with the bulky right-hand grip common among DSLRs. But should come with its three detachable grips of different sizes to balance better with lenses of different sizes, and for holding preferences when handling the camera other than when shooting. Very unique. No solenoid, no problem. You'd be set for a very long time. My view is, when upgrading only after many years, might as well take a big jump!
Not forgetting, of course, a new K-70 combo with the DA 18-135mm WR lens as a prepackaged kit, from a reputable high-volume dealer should be a late-production camera and thus should be safe, and a bargain for what you get. It too is exceptional for low light shooting.
The very useful DA 18-135mm WR lens would also work beautifully on your K200D, complementing its WR design, as well as on recent models. Again addressing low light shooting, this lens can keep to f/3.5-4.5 between 18-70mm- only about a stop off the expensive 16/17/18-50mm f/2.8 constant-aperture zoom lenses which are quite expensive, large and heavy.
Another very good lens for low light use and for much more, look around for a perfect FA 35mm f/2 prime lens, which can deliver fine quality imaging, even at wide open aperture. This is also a good FL for a compact and useful walk-around prime lens. Although not really all that expensive, if you can get up the money, consider getting a new one- the new HD version (has High-Definition coatings, reducing flair and improving clarity, along with an upgrade in its body design), which is well worth the cost.
