Originally posted by Sandy Hancock Oops, I thought you already had it! But the same applies to the FA43.
The FA77 is fantastic on both crop and full frame
I also have
a lot of older full frame lenses. That's why I'll always have a K-1
Same here! My experience is much like Sandy's. It's been APS-C right along for me, and although I had arrived to the point of being very satisfied, I rather knew I was still missing out to some degree with only my DA lenses, of which I have very good ones, and using other FF lenses in this more narrow FOV. But I did not realize how much I would enjoy having my K-1 II and employing fine FF lenses again in their original FOV, and with the superior IQ of the K-1 II, until I finally did so! The same above also applies to the excellent yet modestly-priced FA HD 35mm f/2. A terrific multi-use FF prime lens on the K-1.
Many of my old film-era lenses sat unused for some years, and it has been a revelation in some cases to put them on my K-1 II. One of these favorites is my Tokina 28-70mm f/2.6-2.8 ATX Pro II, which though built like a tank, is essentially no larger than the new DA* 16-50mm f/2.8 PLM, though to be fair does not go quite as WA, yet also to be fair- is a FF lens, not APS-C! I love it on my K-1 II. Its performance has been great, and its screw-driven AF has been surprisingly good. My choices for use with my K-1 II are relatively light for FF ensembles. I can go about comfortably enough, with advantages gained in IQ and in low-light performance.
But when going more into the tele range, and/or when dealing with more extensive walking or bike-riding, its the APS-C alternative every time, which is yet more manageable and even more compact. My APS-C options are so good now, I often marvel at how capable this gear is for how relatively well it totes. Since you already have the DA* 50-135mm f/2.8 WR, it seems it would become it to have a lower half of the zoom range with which it could couple, and to complement its relative compactness. But the new DA* 16-50mm f/2.8 AW PLM is nearly as long, wider, and actually heavier than this DA* tele zoom lens! If needing the f.2.8 constant aperture, well you need it. Otherwise, the DA 20-40mm f/2.8-4 Ltd makes a wonderful and truly compact ensemble with the DA* 50-135mm lens.
Advancing one thing at a time is the best way to go, as I see things. Easier on the finances too. Incidentally, the VF of my KP, while not having the magnification of the K-3 III (one of its claims to fame), it was an advancement over that of my K-5 IIs, which I still have and sometimes use. This went from 92x to 95x, enough to make some difference.
