12-20-2008, 09:37 AM   #1
Shutter Speed
I have had a K100D for about a year and a 1/2. Starting about 2 weeks ago, when I take a picture the shutter stays open to long. I have not made any changes to any settings so I do not know why this is happening. I thought it might be a battery issue. I use rechargeable batteries so I put in a fresh set of non rechargeable batteries and I still have the same issue.
Does anyone have any idea's what might be causing this?
Thanks
12-20-2008, 09:49 AM   #2
k0og's Avatar
Welcome to the forum.
I'm sorry to hear about your shutter problem. I suggest that you go in the CUSTOM SETTING menu, last item, and execute the "Reset Custom Fnction" item to do a reset. Then turn the camera off and back on and see if it works properly.
You might also try a different lens, or at least removing and reattaching your lens to make sure that all the contacts are properly made between lens and camera body. You might also gently wipe the contacts on both the lens base flange and camera body mount with a dry soft cloth (like a handkerchief) to make sure all are clean.
Let us know what happens.
-Joe-
12-20-2008, 10:33 AM   #3
I went in and reset it and it seems to be doing better. Thanks
12-20-2008, 10:38 AM   #4
krs
I presume the exposure compensation is set appropriately (at zero, or close to it)?
batteries, camera, dslr, issue, photography, shutter
Shutter speed on K-x CrabShadow Troubleshooting and Beginner Help 7 08-14-2010 06:46 AM
K7 Shutter speed with flash in Av dnmtsn` Flashes, Lighting, and Studio 15 05-25-2010 04:08 AM
what shutter speed did i use? pete_pf Pentax SLR Lens Discussion 9 10-20-2009 01:45 PM
Shutter speed?! seymop Pentax DSLR Discussion 4 10-02-2007 07:28 PM
Shutter Speed? ryanmkk Pentax DSLR Discussion 4 11-15-2006 03:27 AM
All times are GMT -7. The time now is 03:29 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
