If you're running (or upgrade to) firmware v1.30, you don't need to use a program to put the K10D in debug mode
- Create a file MODSET.TXT with
[OPEN_DEBUG_MENU] as the first and only line
- Copy the file to the root directory of your SD card
To enable Debug mode,
- Turn the camera off
- Open the SD card door, insert the SD card with the file on it, and leave the door open
- Turn the camera on... the Debug menu will appear on screen
- Close the SD card door
- Set the Debug mode and to Enable
- Press "OK"
To Disable Debug mode,
- Turn the camera off and back on again
- Set Debug mode to Disable
- Press "OK"
