Hi, I am a beginner learning all about histograms. As an experiment, I took a photo of a gray card, pretty much filling the frame, and I got the histogram attached. I am surprised that the spike is so far to the left, but should I be? Is that the way my camera is designed to work? I would have thought that the meter would put the average value closer to the middle. (If I understand correctly, IrfanView is telling me that the midpoint of the spike is around 82 on a scale from 0 to 255.)
I am using a *ist DS2, FA 50 f/1.4 lens (also tried manual A lens, not much difference). Set ISO to 200, white balance to Daylight. Aperture at f/1.4, Av mode. Center-weighted metering. Had camera on MF, manual focusing.
If this is unusual, maybe it's because I'm using a KatzEye focusing screen (not Optibrite).
So, basically, I am wondering whether my camera is metering as intended. Is it normal for a DSLR (or a Pentax DSLR) to meter in such a way that this is the histogram that results, in these circumstances? I realize that this is kind of an elementary question. I did do a search, but I wasn't able to find an answer, so thanks in advance!
Mark
