Originally posted by lotech Hi there,
I am looking for a wireless trigger for my K3 Gen 1, as far as I know all K models are using the same type of remote, simply 2.5 or 3.5mm jack with on/off switch. I found some cheap wireless triggers like this one with interval timer, the special thing about it is it can be use wired too, but Pentax still not a hot brand so without the cable for it, I wonder if I could simply buy any model and change/make the cable myself, any comment ?
https://www.aliexpress.com/item/32839895505.html?spm=a2g0o.productlist.0.0.4...d=Hrk40e4FiH2G Get the one with the E3 cable end. that will go into the remote socket of a K-5. The site you mention says it will work with:
For Pentax:K-5,K-5IIs, K-7,K-30, K-50, K10D,K20D,K100D,K200D,
and Pentax has not changed its remote connections for its digital cameras.
If you were just wanting an infrared remote trigger the is the Pentax Remote F and the weather sealed version as well. The remote trigger that you link to has many additionall functions.
Regards
Chris
