Originally posted by UncleVanya How do you see dust from the sensor getting onto the focusing screen? The mirror will be locked up and the screen will be closed off when cleaning the sensor.
Oh, I have done it two or three times (before I retired the practice from my repertoire). Whether the dust got blown on one size of the focusing screen or the other, or somewhere on the Prizm, or even stuck inside to the viewfinder, I have done it. Perhaps others in the forum, here, can testify that it can be done.
---------- Post added 12-26-22 at 02:02 PM ----------
Originally posted by btnapa Be very careful. I actually created a mess by using an old rocket blower that sat around for a long time. I had maybe 4 or 5 small dust spots on my sensor. I thought I was going to blow them off the sensor with the rocket. As it turned out, the rocket had plenty of dust inside and I made a mess requiring professional sensor cleaning. The particles that the rocket blew on to my sensor were so microscopic, you could not see them with a naked eye. They were noticeable when you shot a sky image. It was a total disaster! The professional cleaning gave me back a pristine sensor again. Be careful.
Thanks for your testimony, and a good reason/reminder for all of us to store the rocket blower in a tightly seled zip-lock bag...
---------- Post added 12-26-22 at 02:03 PM ----------
Originally posted by kypfer I guess it's all down to how powerful or energetically used the rocket blower is … remember, you're trying to shift a speck of dust an inch or two, not blow it into the middle of next week
LOL, very good advice! That is, that we're not trying to launch a rocket to the moon when squeezing the rocket blower...
Originally posted by Wingincamera I have used a Rocket Blower without any known problems. I always store it in a plastic zip lock bag to keep it from gathering dust while not being used.
Storing it in a plastic zip lock bag is excellent and very wise advice!
---------- Post added 12-26-22 at 02:04 PM ----------
Originally posted by Wheatfield Cue the angry kittens.... I use canned gas.
I certainly would hold the can as far as possible away from the camera when doing so... One good thing about this technique, however, is likely no or very very few dust particles are in the can, like in a rocket blower that has been sitting around, out of a zip lock, for a while....
---------- Post added 12-26-22 at 02:06 PM ----------
Originally posted by c.a.m My story is simple.
I used a rocket blower once to remove dust from my camera's sensor. It deposited more gunk than it removed, which required a gel stick and a wet cleaning
Since then, I use the Pentax O-ICK1 gel stick and Eclipse liquid swab-cleaning, when required.
- Craig
Yep, I have virtually retired my rocket blower for cleaning the sensor. I don't have the Pentax brand stick, but I do have an off brand one that works fine.
---------- Post added 12-26-22 at 02:09 PM ----------
Originally posted by Ian Stuart Forsyth I always first use the blower to remove any dust, if not this could cause you to scratch the sensor if it is hard particle. The out surface of the sensor is rather hard and can not be scratched unless their is a hard object coming into contact is hard.
Here is a razor blade scratched across the surface of the sensor
here is the track of the blade
A close look at the track
And it did not scratch the sensor
This is not to say that you will never scratch your sensor but the most important first step is to remove any particles that can be a method that put no pressure on that particle and the surface of your sensor blow it off.
Then I use a fan brush to loosen any remaining spots and then again use the blower to remove loosened particles. And then if needed a swab or but most of the time a sensor klear pen for stains and oil.
A razor blade, eh? You are very brave or doing this to a sensor you have no use for. But you have educated me/us, that the sensor is much much harder to scratch than originally thought!
