I have a number of cameras I use for infrared.
I started out with my istDS. As has been mentioned the UV/IR cut filter is fairly weak in the early DSLRs so IR is possible, although long shutter speeds are required. False colour infrared images are easy to produce with a simple channel swap, as well as the usual B&W. I use a Hoya R72 filter on it.
Here's an example.
Then I picked up a Sigma SD14 which like a number of the early Sigma DSLRs has an easily removed UV/IR filter, converting it to a full spectrum camera. I picked up an M42/SA mount adapter so I was able to use my M42 Pentax lens on it.
I never had success generating false colour images but for B&W I find it excellent.
I also found an article on simulating the old Kodak Aerochrome look. Set the white balance to tungsten and use a green filter. The resulting image has a very distinctive look.
Then I acquired converted istDL2 where the UW/IR cut filter has been replaced with a 720nm filter. This allows for regular shutter speeds and lets me choose from all my lenses. A converted camera is the easiest to use.
I also have a 720nm converted P&S camera, a Luminx DMC-SZ7 but I've never been happy with the results I get with it.
Lots of other examples in my
infrared album on Flickr.
p.s. Hmmmm, now I understand what my wife means about me having too many toys
Happy New year all.
