Originally posted by Michael Piziak The medium format size coupled with a 50 megapixel sensor is certainly attractive to me when it comes to the detail one can capture. Of course, the size & weight of the 645z is something to consider as a downside (I haven't even looked up it's weight, but can see it's size is manageable & perhaps even desirable from videos I've seen).
I guess the traditional answer to this dilemma still applies, but now not nearly as much. It largely depends on what you shoot, what you will do with it, and how you go about your photography. With 35mm film vs. MF, traditionally the superiority of MF showed itself to advantage in large blowups, as the image would not need to be stretched as much to get the blowup. The same is still true- however, the resolution now attainable from a top-level FF model is so good, this difference won't begin to be demonstrable until that blowup is of very large size. And, as technology keeps advancing, that gap is narrowed even more. If you are not doing large blowups, whatever advantage there might be eludes detection.
Then there are the downsides of the MF technology. As long as you are shooting what MF has the potential with which to demonstrate superiority (now reduced by comparison to the latest FF products), you MIGHT at times be able to visualize this superiority. Of course, not all viewers will be viewing your full-size effort and zooming in on an eye. Additionally, your efforts will need to be confined to subject matter where FF can work to any advantage. The FOV range of WA to tele will be reduced, as the lenses for such coverage will become enormous and enormously expensive, yet still be reduced in range. And, forget thinking about action shooting, faster AF, etc. Flash sync will also be reduced. You could easily wind up with a less widely-capable system, while giving up those other practical and functional advantages, but can provide some image detail advantage at times which is difficult or impossible to visualize.
Finally, there is the manner in which you operate. Then size can matter in the opposite way- becoming an encumbrance. This can mean fewer shots that will be as easily doable.
Getting back to the issue of fine detail in images, again, technology keeps advancing, narrowing that gap. Now on the horizon will likely come the K-1 III. It will most likely employ the same 45.7 sensor as the Nikon D850 and the top Nikon mirrorless models. This essentially 48mp sensor is of about the same amount of pixels as the 51mp Pentax 645Z MF model, but is within the FF size format, creating greater pixel density, with the potential for capturing even finer detail!! Especially in tele shots, where it is often beyond reach of the MF model, even if it had its largest available lens. At most advantageously fair comparison for the MF setup against the latest FF, it would be like comparing the APS-C Pentax K-3 III, with all its advancements, to an older 24mp FF model, and thinking the older 24mp FF model will provide greater resolution because it is FF. But in that case, if you get the same framing of a subject either by getting closer with the FF camera, or by using a longer lens of the same quality from the same distance, you would still be getting no more than about the same MP in the frame between the two cameras! There "might" still be some advantage, but it would be minuscule at best. You would be stuck in having to get closer to your subject, or in having to use a larger, more expensive lens for a similar result. In the case of the 645Z against the latest FF setup, the 645Z would not have the FL range in lenses to compete in this manner.
