Originally posted by Rush2112 Mostly fixed fixed it? What made you say that?
What mistakes with tracking?
I am talking about plane shooting, so it may not apply to all scenarios but: on zone AF or full auto it tends to switch from initial object to other things, mostly when they are in brighter colors. With big objects it randomly moves focus point from closest, to biggest, to most bright etc. While it is not an issue on big distances as DOF is enough to cover whole object, with closer ones and smaller objects it can ruin your shot when AF is switched from hull to tip of the wing. It also tends to select random AF points even outside of moving object - for example you aim for starting plane, it is only(!) object moving, it is in the center etc and K-3/3 focuses on runway grass cause why not.
This all made me use only spot or SEL-1 for AF-C. So while it is tracking well if you tell him exactly which point to track, it is not, for my needs, to keep tracking of selected object in zones or auto modes. There are still things in software (I think this is the case) to be fixed or improved.
