Originally posted by GUB
Unfortunately once the addiction kicks in this is not the case after buying almost 400 of them
Wow, how many years ago did your addiction kick in ?
---------- Post added 01-09-23 at 09:01 PM ----------
So, I decided to grab the kit lens and take some shots from F5.6 up to around F16. I didn't do any auto leveling or any type of post processing, so try to just look at the sharpness only please.
So, someone in the thread said that F8 is the aperture that starts to hide the flaws of most any lens or makes a lens shine as much as it will. Someone do tell me, since you guys/gals told me to take the previous photos wide open, I assume that wide open shows most lens flaw(s), eh? And is it generally true that the higher the F number then the less flaw? Or, does the lens get better as it approaches F8 from either end of the aperture spectrum?
ok, here are the photos from the kit lens (the Pentax 18-55mm kit that comes/came with so many Pentax DSLRs).
Starting with the first photo, the F numbers of the photos are 5.6, 6.3, 7.1, 8, 9, 10, 11, & 16. All photos taken at 50mm
Of course, keep clicking on any image to keep zooming in closer and closer to view sharpness
I haven't looked at the results yet myself, but here they are.
f5.6
f6.3
f7.1
f8
f9
f10
f11
f16
Again, I haven't looked at them yet. But a year or so ago someone said the Pentax 18-55 was no slouch for a kit. You tell me. Also, I'm still interested in your comments on how the kit compares to my other 3 Pentax M lens in this thread...
Lens set at 50mm Question about that, what mm would one/should one consider the lens to be the sharpest?
---------- Post added 01-09-23 at 09:14 PM ----------
For a quick comparison,
Here is the Pentax 100mm M macro prime at its best:
The Pentax 50mm F1.7 prime lens
& the Pentax M 50mm macro prime
The F.17 and 50mm macro didn't have the luxury of being shot many times to pick out the best like the 100mm macro and kit lens did....
---------- Post added 01-09-23 at 09:37 PM ----------
And a side by side comparison using low resolution Screen Shots via the computers Print Screen key. I didn't shoot the 50mm macro many times to give it a chance. But question: Should one consider the 50mm macro to be less sharp than the 100mm macro for some physics reason (?)
The 50mm M Macro F4 was updated t 5:05am U.S. Eastern Time
100mm Macro F4
F1.7at F1.7
50mmMacroF4
KitLensatF5.6
kitlensF5.6 by
Michael Piziak, on Flickr
55-300mm lens F4 - just added on 1/12/2023 at 11pm
