Originally posted by GUB I have a M100 f4 with separation too. Bad enough to not use.
But I also have a s-m-c 100mm f4 m42 short focus bellows lens that is fine.
They are all 5 -3 design so maybe it is a cement issue.
Yes, I don't think I'd be stretching out on a limb if I made the statement that most, if not half, of the Pentax M 100mm macro lens have separation. The last one I bought, I bought it from an estate sale where the father was the only owner and the son said he barely used it (it was kept in a case in storage for many years). Heat could be causing the separation in this lens. The 50mm f4 macro M lens does not have, reportedly, the lens separation issue.
I have the 3, Pentax brand, extension tubes, and I like using it with the 50mm macro. For those that don't know, the extension tubes on the 50mm macro makes the lens magnify much more than the extension tubes on the 100mm macro - I don't know by how much magnification, perhaps someone here could enlighten us...
I owned the 100mm before I owned the 50mm macro, and many above acceptable macro photos have been taken. Here are a few:
14374656390_0bcf39d25f_o by
Michael Piziak,
So, the lens separation hasn't convinced me to let go of the lens. Of course, the largest advantage of the 100mm is you can be farther away from your subject when taking a photo - much advantageous when the subject is live.
