Originally posted by rodrigogalvao
I basically use manual lenses on my cameras (a Pentax-A 28mm f2.8 and a Pentax-A 50mm f2 on a K5 or K30).
I wonder if anyone has ever compared the depth of field using the aperture ring on the lenses versus the digital aperture in camera - and if you noticed any difference in results, ever in depth of field or sharpness.
I'm not sure I am understanding the exact nature of your inquiry, but you do not have to engage the aperture ring to make use of the distance and DOF scale on the lens. After using these scales to determine the aperture best for the purpose, you simply set the aperture as indicated via the camera's aperture control. However, there is only so much room on a lens for a DOF scale, which of course then has to be more approximate than an outboard DOF scale can be.
I do not think your K-30 has one, but your K-5 has optical DOF viewing, which is using your own eyes to evaluate what is or is not sharp, as long as the lighting is adequate to do so. When using this device, the lens will stop down to your chosen aperture, which will make for darker viewing. This control is at the far travel of the On/Off lever around the shutter button. If practical, it would seem best to go ahead and use the DOF scale on the lens, such as it is, and shooting in Av or M mode, use the camera's control to set the aperture as indicated, then do a double check by using the K-5's optical viewing through the VF. Finally, take a test shot to see if it is satisfactory. Another important factor- those lenses and their DOF scale were designed for FF use, not APS-C. With APS-C there will be a bit more DOF than there would be using that lens on a 35mm film body or a FF DSLR.
