12-30-2008, 11:08 AM   #1
fliter size?
Can a step down conversion be used on the 18-55 kit lens for dslr cameras? I was thinking of Using some 49mm filters i was given. Does the step down ring show up in pictures?
12-30-2008, 11:24 AM   #2
Marc Sabatella's Avatar
QuoteOriginally posted by bergfire Quote
It would in some, not others, depending on focal length and aperture.
12-30-2008, 11:41 AM   #3
Moderator Emeritus
Even though the lens is 52mm for filters, Marc is right. Without testing, the lens should be fine at focal ranges around 35-55mm but will likely show some significant vignetting from around 30mm to 18mm. It has a tendency to vignette without any filters at 18mm when wide open. So you'll see dark corners in wider shots.
Welcome to the forums as well.
camera, dslr, photography, step
Image Size vs Document Size vs Resolution vs Resampling vs ... AHHHH! veezchick Digital Processing, Software, and Printing 13 08-02-2010 03:57 PM
Which size do you print? jms698 Digital Processing, Software, and Printing 23 12-30-2009 06:38 AM
What size ? netuser Troubleshooting and Beginner Help 3 09-19-2009 02:49 AM
Size does matter... schmik Pentax SLR Lens Discussion 18 04-08-2009 06:28 AM
16bit, colorspace-1, size-1 -> 8bit, colorspace-2, size-2 deejjjaaaa Digital Processing, Software, and Printing 3 10-09-2007 07:55 AM
All times are GMT -7. The time now is 05:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
