Originally posted by Duncan-Jacob Update: I found a K-1 Mk II camera in mint-condition close to home at what I think was a great bargain, though certainly not cheap ($1000 with a few extras and less than 20,000 shutter count).
At that price and shutter count, it seems like a bargain to me! And of course not actually "cheap", but to get even a higher quality APS-C former flagship in fine condition, which I always advocate when buying used, it would not be really "cheap" anyway. I would likewise suggest putting off getting an M42 adapter. Better to add what you need as your experience dictates what those needs will be. Congrats on such a find! I wonder what those "few extras" are?
---------- Post added 03-26-23 at 05:14 PM ----------
Originally posted by Duncan-Jacob Thanks everyone for your help! I look forward to sharing my journey (and asking a bunch of beginner questions).
You are very welcome, and don't hesitate to ask away. We would be glad to have you share your photographic journey. While getting into a structured class can be a good idea, if you can fit your own schedule to theirs, it will ultimately be your own active picture-taking that will lead your way. Experience is the best teacher, and we don't mind giving free help in your doing this on your own time schedule, and at your own pace.
I shot exclusively with film for over 30 years. When I started, there were no interchangeable lens cameras with auto anything. The common point-and shoot cameras back then simply had fixed FL lenses, fixed apertures, and fixed shutter speeds, with instructions as to daylight use, or to use a flash bulb, and how far away a subject has to be.
"Serious" SLR IL cameras were all manual-only for focusing and setting exposure via the camera's built-in light meter, which was the cutting edge advancement. The technology then was also good for learning, due to the lack of automation. Then came auto-exposure in the form of Aperture Priority, now called "Av" (Aperture value) where you set the aperture via the lens aperture ring, while the camera in response sets the shutter speed for a "correct" exposure according to the camera's light-meter reading. Then came full Program auto-exposure, where the camera sets both automatically. Then came autofocus (AF). I welcomed all of these advancements. I did not get into digital until 2006, and then continued simultaneously with film for a number of years more, before digital reached the level where there were clear advantages and no disadvantages.
But through my experience, I could more easily recognize how and when these auto functions would likely not be best, especially under what conditions the camera's meter would be fooled, and not provide a good exposure from its reading. It is in recognizing such matters in advance, then putting the camera's available controls to use for adjustments, that a good outcome can be had.
First thing to do with a used camera is usually to do a reset to factory spec, in case the original owner has established some setting or other that would now be unwanted.
Using the lenses you now have on the K-1 II, you will need to put the mode dial to Manual Mode. Point the camera to get the framing you want of your scene, then to get a "proper" exposure according to the reading of the camera's light meter, hit the green button and there will appear a shutter speed already set by the camera. Although set to Manual Mode, this is actually AV- Aperture priority auto-operation. Unlike your LX, you cannot set to Manual Mode and get a visual reading by the camera's light meter, to then determine and set your own aperture AND shutter speed. So it is quite different than the way I learned photography, a large part of that being the ability to recognize the conditions under which the camera's meter can be fooled, and how to override its recommended exposure to set a corrected value, and for certain effects you are trying to achieve. It can be part of that process as well as an education, to be ABLE to point the camera around a scene you are confronting and get visual meter-readings as you go! Especially when switching to spot-meter readings. You could do just that with your LX. But trying that with one of your lenses on the K-1 II will give NO indicator for visual meter readings, just with the green button providing shutter-speed readings only. You can use the LX in AV mode and get the same, but this is not full Manual operation.
However, there IS a way to establish full Manual Mode with both cameras. You'd need a lens that has an aperture ring, but one that has the A setting. You can then get full metering readouts on both cameras. I have one to suggest- the FA 28mm f/2.8 AL lens, which is also AF capable. It would simultaneously provide a significantly wider angle FOV than your 35mm lens., thus adding to the range of your kit. 28mm is a favorite among photographers for general usage. It is an oldie but very goodie, providing excellent imaging, sharp results edge-to-edge even wide open! It is small and easy-carrying on your K-1 II. So you could switch it back and forth between both cameras functioning fully in the Manual Mode, but with the ring being set on "A" when on the K-1 II, so you set your aperture with the camera's on-body control. As good as it is, this lens can be found in top condition for a very reasonable cost.
