Originally posted by Duncan-Jacob I believe that I would get more experience than only shooting film and instant feedback from the digital display.
This is one of the paramount advantages of a digital interchangeable lens camera over a film camera. Even for a photographer with years of expreience with film -shooting, the instant feedback is useful, even though film exposure generally turns out as expected.
---------- Post added 03-25-23 at 01:39 AM ----------
Originally posted by Duncan-Jacob Film is expensive to learn and feedback to get better is slow.
It continues to be expensive after you know what you are doing.
---------- Post added 03-25-23 at 01:43 AM ----------
Originally posted by Duncan-Jacob I would like to add an affordable digital camera to assist me with learning photography more efficiently.
Indeed so! However, a Full-Frame choice to learn photography is certainly not "affordable" in the usual sense of the word, and compared to other just as viable options.
There definitley are much more affordable options by comparison in going for an APS-C model instead of FF. The techniques for good photography are the same for either format. Once you learn these, and are having a good time with your digital equipment, you are likely to find yourself using your otherwise fine LX camera less and less. Another advantage for digital is to adjust for certain conditions, and to get a good characteristics match of one film for a certain purpose over another type of film, requires changing films, sometimes in mid-roll, where with digital you would simply adjust some parameters in the camera.
Many of us have come from years of shooting film, and now rarely do so. It has become very much a niche interest. Being that you'd be apt to wind up like most of us in this regard, it would not be all that wise to spend that much up front until gaining experience enough to detetmine what your photographic interests might turn out to be. APS-C and FF each have their own advantages depending on these interests, and how you go about persuing those interests. One example is, your 55mm f/1.8 lens would be excellent as a portrait lens if used on APS-C, while to get a lens with an equivelent FOV and f/# for use on a FF body would be quite costly!
The angle or field-of-view (FOV) changes when using the same lens on APS-C compared to FF, otherwise FF lenses are fully usable on APS-C. The only (moderately) wide-angle FOV on a FF body among your lenses is the 35mm lens, and it would no longer be a WA lens at all on APS-C, but would be a "normal" FOV lens, like a 50mm lens on a FF body. Your other lenses when on a FF body, are within a "normal" FOV, except for the 135mm lens which is a modest mid-telephoto. On APS-C, all of those other lenses would be in the short-to- longer tele range, as your 135mm lens would then be like a 200mm lens on a FF body. Many of us who shoot with both APS-C and FF models have become quite used to dealing with these FOV differences.
So you might consider getting a good APS-C body and perhaps a zoom lens with both wide angle capacity and some telephoto, which would provide versatility for you to explore your interests. Your present lenses could serve especially for conditions where light is low and/or there are moving subjects, as their f/ numbers show them to have large apertures to let in more light than most zoom lenses are capable of.
