01-02-2009, 12:11 AM   #1
i got a clunk
ok everytime i turn my k200d on i get this double *clunk* sound. it's only recently started doing it even though it's not affecting any pictures at all. Has anyone else experienced this and have found out what the problem was.... is it terminal, or can it be fixed... the camera's still under warranty so i should be safe there etc. any thoughts?
cheers
Grant
01-02-2009, 12:14 AM   #2
Igilligan
Guest
sounds like the dust cleaning clunk. Do you have sensor clean enabled?
01-02-2009, 12:14 AM   #3
mike.hiran's Avatar
QuoteOriginally posted by shed301 Quote
cheers
Grant
I wonder if you have sensor cleaning on upon startup activated? I think you may be feeling the sensor shaking...
01-02-2009, 12:32 AM   #4
thanks guys...... problem fixed and i have no idea how that got activated
01-02-2009, 03:02 AM   #5
Longboarder's Avatar
Great to hear that the problem is solved.
Just in case it helps anyone - on a similar note, I was using my GX-10 last night, and after every shot the camera was making a strange noise.
Then I discovered that I had bracketing multi shot switched on. I was not holding the shutter release down long enough for the second shot to be taken, but the camera sounded as though it was getting ready for the next shutter release.
D'oh
01-02-2009, 03:03 AM   #6
I wouldn't call it a 'problem', it's a good thing. I think it's one of the camera's default settings.
01-02-2009, 04:06 AM   #7
Moderator PEG Judges
Kerrowdown's Avatar
Hey shed301, kinda worrying ain't it, the first time you hear it........
01-02-2009, 05:52 AM   #8
Andi Lo's Avatar
When I started using K100D I also noticed that a part inside the camera moves around everytime I change sides in portrait orientation. Turned out it's the magnet used for SR Is this the same in K10 and K20?
01-02-2009, 11:30 AM   #9
KjetilH's Avatar
I did not compare directly, but I think the sound is reduced in the K20D. : )
01-02-2009, 12:19 PM   #10
Igilligan
Guest
I dont know about that... the clunk sounds like something coming apart in my K20.
I am also not hearing a big difference in the volume of the shutter that I heard so much about.
The tone of it may be a little lower but the volume seems about the same.
01-03-2009, 11:09 AM   #11
QuoteOriginally posted by kerrowdown Quote
yeah it is... the only thing that went through my mind when i first heard it was <insert bad word here> dollar signs flashing through my eye's. My main worry was that it would have been getting fixed during the A1 GP being held in taupo New Zealand on the 23rd of this month and returning to the event using the sony cybershot again wasn't in my plans.lol.... So i'm very relieved it's back to normal
grant
01-03-2009, 03:45 PM   #12
ivy
something moves inside my camera
Hey all,
I just bought a K200D yesterday. I didn't notice when I first bought it, but when I took it home and tilted it side to side something heavy-ish inside the camera was moving left to right by about 1-2mm.
Is this a fault or is this normal? Has anyone else noticed something like this with their camera?
01-03-2009, 03:49 PM   #13
Marc Sabatella's Avatar
QuoteOriginally posted by ivy Quote
It's due to the Shake Reduction system - the sensor is free to float around inside the camera a little until the SR system takes control. Completely normal.
01-03-2009, 06:13 PM   #14
ivy
oh that's great. thanks for that.
camera, dslr, photography
Beginners question about noise (clunk) in a Pentax DSLR DV8 Troubleshooting and Beginner Help 62 09-25-2013 06:04 PM
DA 70mm Ltd. 'Clunk' bikecoboss Pentax SLR Lens Discussion 3 09-03-2010 09:59 AM
K7 internal clunk noise grouse Pentax DSLR Discussion 12 04-21-2010 04:02 PM
Used K-x body clunk, gross fungus stuff? Cybe Photographic Technique 11 01-28-2010 08:07 AM
Pentax K7 clunk kiamon Troubleshooting and Beginner Help 13 12-26-2009 08:34 AM
All times are GMT -7. The time now is 12:51 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
