Originally posted by robgski That's never going to change. As the saying goes "It's a poor craftsman who blames his tools".
This is a rant regarding the poor craftsman nag. It is not directed at you. I triggered a bit when I read your post, but it's one of those things that bug me because I think it's it's overused.
It is only true to an extent. After that, it's the tool.
Example 1:
My old jobsite table saw served me very well when I was doing framing carpentry and renovation work, but it had too much vertical movement in the blade for cutting box joints.
This is the fault of the saw.
The solution was to recognize this failing and buy a better table saw.
Example 2:
My old Nikkor 50/1.2 wasn't sharp enough for what I wanted it to do much of the time. This, again, is the fault of the tool. The solution ended up being to buy a Pentax to get a 50/1.2 that was decently sharp wide open, though a Series E50/1.8 served as a mostly workable stopgap.
Example 3: I have a set of Narex chisels that are quite good, but they won't hone to quite as sharp as I would like. Again, this is the fault of the tool, it's baked in. I can't blame it for chip out if I choose to use it where it's going to fail though
The solution was to start buying very expensive Veritas chisels that could be honed sufficiently.
It's not always about the craftsman, it is often about the tool not quite being up to the task at hand. Perhaps it's because the craftsman didn't spend enough money to get a tool equal to his skill or good enough to overcome his lack of same, but it's still about the tool.
I don't blame my old jobsite saw for not being able to do fine carpentry, but I had to recognize that it was to blame for the uneven well depth in my box joints.
I get to blame my old 50/1.2 for not being able to give me decently sharp images (it really did start off very soft and never got much better), What I don't blame it for is the quality of pictures I chose to use it for. If I wanted sharp, I was using the wrong tool. It wasn't the lens's fault that I chose to put it on a camera in other than a romantic style boudoir shoot where I could control DOF very tightly without having to worry about the picture sharpening up so much that I had to put on a Softar. The lens did just fine, it was soft right down to f16.
I get the feeling sometimes that "blaming the tool" is one of those things that gets dragged out of the barn any time someone publicly concludes that some particular tool isn't up to a task that has become important to do well.
