Originally posted by northcoastgreg Perhaps this is true of some software, but it's not true of the standalone LR versions which I have used nor of Darktable. When I've used the lens profile, I see no changes in color, just corrections in distortion and vignetting. Now as for camera profiles, while it's true that they can have a big impact, I find that most images I see online are using default profiles. And in addition to this, from twenty years plus years of post processing, I have found that the color and contrast I can get out a lens is generally better than what I can achieve in post. Making really subtle changes in color can be near impossible. My Tamron 70-200 is a nice lens, but it can struggle with green colors (it has a "green hole"), and there's no way to fix that in post---at least not to my satisfaction.
I think you misunderstood my point, Greg, or perhaps I didn't present it clearly...
I wasn't suggesting that
lens profiles have an impact on colour (they absolutely don't - aside from luminance values in vignetting correction, of course). Rather, I was inferring that the lens itself is an unavoidable ingredient in creation of an icc or dcp
camera profile ("
Input profile" in RawTherapee, "
Input colour profile" in Darktable, "
Profile" in Lightroom 6's "Camera Calibration" section, etc.). A so-called
camera profile is really a
camera-plus-lens-combo input colour profile, and using it with any other lens will probably result in slightly (or even considerably) different, less-accurate colour reproduction. We tend to forget these profiles are inextricably linked to the lenses used in creating them... and we blithely apply them to all of our images regardless of the lenses
we use (often, I'm as guilty as the next person), then wonder why the colours don't always look quite right (such as your Tamron 70-200).
With your experience in post-processing, I'm sure you'll know all of the following - but give me a little rope if you will, as less-experienced members than yourself may benefit...
For the sake of argument, say Adobe ships a Pentax K-3 "Adobe Standard" profile with Lightroom and they created that profile by photographing a colour chart with a Pentax K-3 and DA50/1.8 lens. When I take photos with my K-3 and DA50/1.8 lens and apply the Adobe Standard profile in Lightroom (which happens by default), I'll see precisely the colours Adobe intended from the profiling process... but if I take the same photo with the K-3 plus my Sigma 17-50/2.8 and apply that same K-3 Adobe Standard profile (which, remember, was created with the Pentax DA50/1.8 lens), I'll see somewhat different colour rendering.
If you photograph a colour chart with your camera plus Tamron 70-200, then do the same with any other lens, and use profiling software to create colour-accurate dcp profiles for each combination, then you can apply the respective profiles whenever you use those specific lenses and you'll see virtually identical colours from both combos (an essential capability in professional product photography where accurate colour reproduction with different camera / lens combos is vital). The reason your 70-200 struggles so much with greens is almost certainly that the camera profile ("input colour profile") was created using a lens with considerably different properties in that part of the visible spectrum. Create a new colour-accurate dcp profile from a colour chart photographed with your camera + Tamron 70-200 lens, apply it to photos you take with that combo, and you won't have that "green hole" problem any more.
Going back to my previous point, where I may have inadvertently caused confusion... All this is to say that the colour reproduction from a camera is less a function of the camera itself and far more a function of the software icc or dcp camera profile, the lens used when creating that profile, and the lens used by the photographer to take his / her photos to which they subsequently apply said profile (by default or selection). As such, raw photos taken with a Pentax K-whatever and Sony A7-whatever can appear wildly different or virtually indistinguishable in colour rendering, depending on the camera profiles applied and lenses used - but it's entirely possible for the user to create profiles that will more-or-less normalise the output from any two camera / lens combos to the point where you can't tell them apart, at least so far as colour reproduction is concerned.
In a fantasy "ideal world", there'd be standardised colour-accurate icc and dcp profiles for every single camera-plus-lens combo, and every raw conversion software provider would use those profiles rather than shipping their own. That way, colour reproduction would be standardised across all cameras and lenses, providing the same starting point for user processing. As it stands, we either have to create those profiles ourselves as needed, or else - as most folks will - accept the differences we see between various camera / lens combos when using the bundled "one size fits all" profiles.
[NOTE: I use RawTherapee 5.8 & 5.9, Darktable 4.2.1 and Lightroom 6 stand-alone. The above applies to all these, and any other raw conversion tools that support user-selectable input profiles in a colour-managed workflow...]
