01-02-2009, 05:36 PM   #1
My technique to focusing in extreme low light
I just zoom in focus it and then zoom out to my original frame like i use to do when i was a tv cameraman. Does anybody does that to make sure your k20d is in perfect focus?
01-02-2009, 05:43 PM   #2
mickeyobe's Avatar
Vic,
I do that with my K100D.
I did that with my Canon T90.
I did it with my Canon Ftb.
Also with my Exakta VX IIa.
There is nothing new under the sun.
Mickey
01-02-2009, 07:50 PM   #3
mithrandir's Avatar
Works for my K10D as well.
01-02-2009, 10:06 PM   #4
QuoteOriginally posted by mickeyobe Quote
Vic,
Mickey
Someone ELSE used to own an Exakta?!?!
Wish I could remember the exact model (no pun intended).
Great little camera that I "cut my teeth on" photographically speaking!
01-02-2009, 10:39 PM   #5
heliphoto's Avatar
With some of my lenses this works (the DA* 50-135 for sure), but with others, the focus needs to be adjusted differently at different focal lengths.
01-02-2009, 10:59 PM   #6
soccerjoe5's Avatar
For the times I do strobe shooting in dying light, I use an LED headlamp Looks silly but it works awesome.
01-02-2009, 11:24 PM   #7
nostatic's Avatar
zoom? what's a zoom?
01-03-2009, 01:44 AM   #8
Mike Cash's Avatar
The only problem with zooming in under low light conditions comes if your zoom is not a constant aperture. If it is a variable aperture you're actually making your viewfinder darker when you zoom in.
I sometimes put a small LED penlight next to my subject, focus on it, and retrieve it before shooting. If the subject is close enough I just shine it on the subject while focusing.
01-03-2009, 08:37 AM   #9
QuoteOriginally posted by stgmgr Quote
Used to? You guys don't still have one? I do (a VX) and you can quite literally cut yourself on that beast.
01-03-2009, 11:04 AM   #10
Marc Sabatella's Avatar
QuoteOriginally posted by nostatic Quote
For me:
Zoom = a slow autofocus lens I wouldn't even try to use in low light
My low light lenses are all primes - and mostly manual focus. So I have to admit I scratched my head a moment before figure out what the OP meant :-)
01-03-2009, 11:39 AM   #11
I tried this with a 16-50 when I found that I could not see to manually focus on infinity whether in poor light or sunlight. Of course it didn't work;the point of sharpest focus varied from 16mm to 50mm . At 16 mm the cursor had to be set between the lemniscus and the 7m mark to obtain sharp focus whist at the other end it was set on the second lobe of the lemniscus. Other settings were: 20mm,first lobe,28mm and 35mm dead centre.Departures from these settings produced noticeable degradation in focus . And so any point of focus towards the wider end can be a little hit- or- miss. But then those of us who have come to know (and love) the foibles of our 16-50's,know this already.
01-03-2009, 11:47 AM   #12
For me:
scratch it again
01-03-2009, 02:23 PM   #13
Moderator PEG Judges
Kerrowdown's Avatar
You have to be careful with that technique if you have a one touch zoom focus ring, the pull a twist gremlin is alive and well.
01-03-2009, 04:21 PM   #14
well unfortunatly i've started using this maneuver only with the k20d under yellow lights
01-03-2009, 05:17 PM   #15
mickeyobe's Avatar
QuoteOriginally posted by pingflood Quote
I still have my Exakta VX IIa that I purchased new in 1957.
I still think it is an outstanding camera.
Mickey
camera, dslr, focus, photography
Low light focusing milesy Photographic Technique 12 08-19-2010 12:39 PM
Focusing technique JamieP Photographic Technique 7 09-14-2009 09:13 AM
Manual focus in low light - technique? Judd Troubleshooting and Beginner Help 14 07-22-2009 02:00 AM
Low light shooting capabilities GX20 at low ISO cabstar Pentax DSLR Discussion 1 12-04-2008 11:01 AM
Low Light Manual Focusing? sjl7678 Pentax DSLR Discussion 11 08-15-2007 12:55 PM
All times are GMT -7. The time now is 03:19 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
