Originally posted by lotech if we combine few pixels, say 4, to create a larger "pixel", we can increase the sensitivity of the sensor right ?
Well.. The sensitivity, truly, is a fundemental constant of a silicon (or any
* solid-state) detector and cannot be changed. What we increase by this approach is the Signal/Noise ratio.
Now, the "sensitivity" in modern digital cameras is not really a sensitivity. It's gain, applied later in the pipeline. Usually it is done in software, i.e. it's just a multiplier. The greater the gain, the more visible noise becomes. With less noise we can apply greater gain ("ISO") while keeping results in the ballpark of "reasonable". So I would say yes, the approach increases what's camera mfgs are naming sensitivity.
Somewhat similiar trick is used in audio. There's a kind of Analog-to-Digital converters that are just a 1-bit but very-very fast ones. So they produce a high-rate stream of bits, which then is downsampled to a high-resolution (16-24 bit) stream with a "normal" sampling frequency.
* except for the avalanche diodes.
