Originally posted by gatorguy I've seen that claimed over and over. What I've never seen is photographic evidence sourced from a users image. I have cameras both with the accelerator and without, and even those with aren't implying it across the entire ISO range (unless it's from Canon). I don't find any obvious detail loss. If it's there it's gotta be darn subtle, to the point it can't be demonstrated except in some very extreme or patently oblique circumstance.
Simple. When there is no accelerator chip, it's the image processor doing the noise reduction job at higher ISO settings. So if you compare image from K1 and K1 II, there is little to no difference (beside the difference between the hardware filter response in the accelerator chip, and the software filter by the processor). In K1 II the accelerator takes the noise reduction work load off the main processor, hence its name "accelerator". To find out, take the same picture, raw, at ISO100 (underexposed 5 stops) and ISO3200, then pull the 100 ISO image 5 stops in your raw developper, disable any noise reduction/sharpening, compare images for noise. Normally, you'll have more noise and more details in the ISO100 image, evidence that the ISO3200 capture went through a noise reduction filter, even when ISO NR is disabled, with a K1 (without accelerator).
