01-02-2009, 06:54 PM   #1
K20 Advice on AF Adjustments?
Is there a need to adjust AF on the k20 out of the box? or it adjustments needed only for older non-DA or FA lenses?
thanks
btw; how do you adjust AF?
tahnks
01-02-2009, 07:17 PM   #2
You should not need to adjust anything unless you have a lens that front or back focuses. You can do some basic testing (just line up a row of batteries diagonally and shoot that with the lens wide open) or use a focus testing chart to see if your lenses have any issues. But don't bother with it unless something seems off in the first place.
01-02-2009, 09:29 PM   #3
Lazaruscomeout's Avatar
Focusing with a fast lens, wide open in tungsten light is a problem for most dslrs, so be careful. You might end up adjusting it so that it focuses correctly indoors, but not in daylight.
I suggest testing the focus in daylight if you think you might have a ff or bf problem.
af, camera, dslr, k20, photography
Need advice for K20 tanyo Troubleshooting and Beginner Help 23 10-17-2010 01:04 AM
Buying advice please: K20 or K7? seeing well Troubleshooting and Beginner Help 7 11-17-2009 10:16 AM
Need Advice - K200 or K20?? Roonie Troubleshooting and Beginner Help 5 03-22-2009 08:50 PM
K20 Novice needs advice holdgaj Pentax DSLR Discussion 2 01-08-2009 02:03 PM
wanted: advice on flash options for K20? Douglas_of_Sweden Pentax DSLR Discussion 5 04-13-2008 03:36 PM
All times are GMT -7. The time now is 10:00 AM. | See also: NikonForums.com, part of our network of photo forums!
