Originally posted by davemdsn
Here is my K10D/Lightroom workflow....
Insert card into reader and open Lightroom (I have the autoloader disabled because not all the cards I put in my reader are for LR). I import into Lightroom using the convert to DNG and copy to... option. I also have a develop preset that I use on import that tells LR to use the Pentax 1.00 profile instead of the ACR 3.7 profile.
Ok ... the $64k question ... why the Pentax 1.00 over ACR 3.7 profile?
I can see a difference in some test shots (using objects that have highly saturated colors), but the difference is minor ... worse in the orange-red area.
The way I see it I may have to back up the PEF's also, because if I choose the wrong profile I'd have to reconvert some of the images with the other profile to get a 'correct' DNG.
Or is this a non-issue - can you apply a different profile to an existing DNG and override the first one without losing any RAW data... and get the same DNG as if the correct profile was chosen to begin with?
And if so... can the profile be extracted from an in-carmera generated DNG? I assume that the Pentax engineers came up with their own (in firmware)...
(lots of questions, I know, but somewhere out there is the right answer...)
Thx,
N
