Originally posted by leikey1982 Yesterday I went out to take some pictures, at first about 10 pics, it is good, but I found it it became tilt, every pics lean to right. After I unmount the lens, I found one side of the mirror is partly out side of the hold frame, I think the frame is distorted, so it can not hold the mirror at the right place. I am pretty sure I hold the camera very well, maybe I am not a expert on photographing, but I still have some experience on photographing, the pictures not only lean to right, but also the objects in the pics distorted. It is shame, I only bought it from someone about or less one month ago(secondhand), only took about 100 pics
. I do not think it is in warranty. Is there a easy way to deal with this problem? Or sell it as a dead body, or only throw it into pacific ocean?
you can throw it my way, my D is getting long in the tooth...
Anyways, a few things to look for.
1)tilted viewfinder screen. The most common complaint in many DSLR discussions of such a problem.
2)Unlikely that it is a tilted sensor...
3)Possible mirror alignment problems (mere mortals advised not to try to adjust it.)
The image is not taken through the mirror so any anomolies here would mostly affect AF and tilt.
For a down and dirty test find a bubble level that you trust, mount it on the hotshoe and test the camera from a tripod, ignoring what the screen sees.... see if it is still tilted. Antishake off of course.
1-3 degree viewfinder tilt is not that uncommon..... in many models/brands.
As to lens distortion, I'm assuming it's just the lens property.
1degree counterclockwise rotation makes it look more on level
