01-07-2009, 12:46 PM   #1
dynamic range K20D
the dynamic range option in the ISO menu
what is this for and when should you use it
Dave
01-07-2009, 12:49 PM   #2
ftpaddict's Avatar
It's there in case you need to extract more shadow detail from the picture and you use it when you need to extract more shadow detail from the picture.
01-07-2009, 11:25 PM   #3
QuoteOriginally posted by ftpaddict Quote
LOL.
So is it like...adding adaptive exposure?
01-08-2009, 01:02 AM   #4
blende8's Avatar
Actually it is highlight detail.
This is from Gordon Goodsman's description: (slightly changed)
What the EDR mode does is to drop the ISO sensitivity to one half of that set in the ISO menu, so that an ISO 200 shot with EDR turned on will actually be using the ISO gain as for a ISO 100 shot but with the exposure values as for the ISO 200 setting, resulting in one stop of extra highlight.
This allows Pentax to expose more "to the right" in the "normal" mode so as to minimize noise while still getting points for a fairly high DR using the "EDR" mode. The downside is "slighly worse noise in the shadows", and the actual effect will be to almost double the deep shadow noise when used at low ISO and reduce the DR at the dark end almost as much as the DR is being increased at the bright end.
It seems to me that one could achieve the same thing more easily by just using a slight negative EV of 0.3 to 0.7 stops with the one stop lower ISO setting and then not require any abnormal post processing of raw images. I can't speak for in-camera JPEG processing of EDR images, as we don't know what extra tone curve manipulations that may be combined with EDR for those.
01-08-2009, 10:51 AM   #5
Das Boot's Avatar
I tried to explain it here: D-Range A Technical View
-Brian
camera, dslr, photography, range
Dynamic Range of K20D and K200D cbaytan Pentax DSLR Discussion 8 05-22-2009 08:04 AM
Dynamic range 200% K20D knumbnutz Pentax DSLR Discussion 13 03-29-2009 03:53 AM
k20d or k10d - which has better dynamic range Michael Barker Pentax DSLR Discussion 10 12-18-2008 10:47 AM
K20D dynamic range enlargement? infosyn Pentax News and Rumors 41 04-30-2008 03:35 PM
K20d Dynamic Range? Don Boyd Pentax DSLR Discussion 2 04-07-2008 04:07 AM
All times are GMT -7. The time now is 10:49 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
