01-07-2009, 05:51 PM   #1
crispy0009's Avatar
Is 1.30 the latest firmware for the K10D?
I'm pretty sure it is. I just want to make sure.
Thanks in advance to anyone who replies.
Chris P.
01-07-2009, 05:57 PM   #2
Yes it is
01-07-2009, 07:24 PM   #3
ftpaddict's Avatar
VERSION HISTORY
Version 1.30
  • Added compatibility with the supersonic motor drive of Pentax SDM lenses.
Version 1.20
  • Added the required programming for compatability with the Pentax Remote Assistant 3 software.
Version 1.11
  • Improved multiple exposure function when shooting in RAW.
  • Corrected an issue with luminescence control and trailing shutter curtain sync when using the built-in flash.
Version 1.10
  • Using the camera\'s built-in flash, you can now wirelessly control external Pentax flashes. Previously, you needed an accessory flash mounted in your camera\'s hot shoe, but now the built-in flash can act as a control flash.
  • In autofocus select mode, you can program the AF button to instantly return to the center autofocus point.
  • In Tv or Av mode, you can now program the second e-dial to adjust your ISO setting.
  • In any exposure mode except Sv and TAv, you can change your ISO setting with the front e-dial while pressing the OK button. The camera will display your ISO in the viewfinder and on the top LCD panel as you adjust your setting.
  • In TAv mode, you can program the green button to return to the camera\'s program line. Previously this functionality was only available in M mode.
  • You now have additional options for programming your e-dials in P mode.
  • Pressing the green button while adjusting flash exposure compensation will now return you to the default value.
  • Corrected an issue in some rare cases where a long exposure might produce a vertical stripe.
  • Corrected an issue where the battery charge indicator would sometimes show empty in bulb exposure mode.
I guess it is.
01-08-2009, 01:26 AM   #4
crispy0009's Avatar
Thanks for the help.
01-08-2009, 03:38 AM   #5
I think pentax need to lauch one more FINAL and corrected for K10D...
camera, dslr, photography
KX what is the latest firmware? jlaubza Pentax DSLR Discussion 3 03-21-2010 01:23 PM
Latest Mac software updates fix K20D firmware 1.01 pef file problems mstahulak Digital Processing, Software, and Printing 1 07-23-2008 08:00 AM
Latest firmware for E10 tacer Pentax Compact Cameras 2 05-13-2008 03:53 AM
No new K10D Firmware yet. maxamillion Pentax DSLR Discussion 40 02-09-2008 10:28 PM
K10D RAW File Support AT LAST in latest Corel® Paint Shop Pro® Photo X2 ! Confused Pentax DSLR Discussion 32 10-26-2007 09:58 PM
All times are GMT -7. The time now is 02:32 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
