01-09-2009, 03:05 PM   #1
Lowell Goudge's Avatar
why don't people like K10D JPEGs
I see lot's of complaints about JPEG quality from the K10D
this is a crop out of a JPEG right out of the camera.
Personally I think the quality is pretty good
01-09-2009, 05:59 PM   #2
jeffkrol's Avatar
Sorry to say that this topic has really been discussed to death. Most of the criticism has been due to the visual effect of "dark side sharpening" creating softer looking edges. Also default sharpening is low. For one of the thousand threads see this:
Re: PENTAX you idiots....fix theK10D sharpness issue in jpg NOW: Pentax SLR Talk Forum: Digital Photography Review
01-09-2009, 09:25 PM   #3
SpecialK's Avatar
Normally the complaint is "I don't like the default in-camera JPG - even though I can easily change camera settings to make it how I like it."
Even some "pro" reviews said this.
01-10-2009, 12:35 AM   #4
Damn Brit
Guest
No complaints from me, I only shoot Jpeg.
01-10-2009, 12:47 AM   #5
Class A's Avatar
They are a bit soft with the default settings.
At Unices.org Blog Archive Pentax K10d, how to make jpg files ? you can compare crops of JPEG vs various RAW engines. You'll notice that the K10D JPEG version is not the one with the most detail.
01-10-2009, 12:51 AM   #6
Mechan1k's Avatar
QuoteOriginally posted by Damn Brit Quote
Pretty much the same here ... and 99% of my pisc I post/upload haven't had any PP done to them at all ... I could do some ... but I am usually lazy or just don't have the time .. so i just post them as well.
No issues here really.
Only options I have chosen on my K10D is Bright Mode and +1 Saturation from memory.
01-10-2009, 06:53 AM   #7
make your own comparison with RAW+
It's easy enough to do: you get your JPG and your RAW.
Convert the RAW with something like DxO, Silkypix, ACR or Lightroom and compare the two JPG's.
Then you'll know whether you prefere RAW or JPG.
01-10-2009, 10:24 AM   #8
I am very satisfied with My Jpegs from the k10. I always thought the pics were good enough for me. I have been shooting only in raw since I got my K20, and your post has motivated me to go out today and play with the custom image mode in the jpeg format.
Thanks for the inspiration
Jeff
01-10-2009, 10:40 AM   #9
Jpegs from K10
Just a street shot of bldg. 6th St. downtown Austin, K10, 50-135 2.8, iso 400, f3.5
Sorry for the 2nd reply thought it would be nice to give an example.
PENTAX K10D  Photo
01-10-2009, 12:03 PM   #10
SpecialK's Avatar
This is one fix for "flat" jpgs. Bright mode increases saturation, and then adding extra saturation makes it even more...colorful. It also made some colors glow like neon on my K100D :-)
01-10-2009, 03:01 PM   #11
jeffkrol's Avatar
QuoteOriginally posted by roverlr3 Quote
I've rarely seen a digital image that doen't need some pp sharpening especially if printing.
Out of Gamut: (Almost) Everything You Wanted to Know about Sharpening in Photoshop but Were Afraid to Ask | CreativePro.com
01-12-2009, 03:10 PM   #12
GeneV's Avatar
Once you have used PS on Raw files, it's hard to go back to camera jpegs.
01-13-2009, 12:58 AM   #13
rayallen's Avatar
Location: Forresters Beach, Central Coast, NSW, Australia
Raw + jpeg
After shooting RAW exclusively for a long time, a month or two back I decided to start an experiment - I set my K10D to RAW + JPEG. For most of the shots I have taken since then I have preferred the JPEG output.
Like Simon (Mechan1K) I find that most shots required no PP. Only occasionally was PP needed to make minor improvements.
I have Saturation and Sharpness set to +1, Contrast set to 0.
Just my 2 cents worth. YMMV.
01-13-2009, 05:31 AM   #14
QuoteOriginally posted by GeneV Quote
perhaps
but if I don't need to use PS why should I. I think that is the point here. I appreciate that you can do a lot with a photo editor, but if you take the time to know your camera, (at least as much time as you spent learning PS for example) you can adjust it to do everything you need.
01-13-2009, 06:24 AM   #15
WheresWaldo's Avatar
perhaps
In a very narrow world this may be true. Let's go back to the analogy of RAW and JPG being similar to Negative film and print. Using JPG only is like telling the local Costco girl just give me the prints and throw away those pesky negatives.
You say that you hardly ever post process, That is great if your intended output is one device and only one device. What if one of your precious relatives says "remember that picture you took of you-know-who, I would love to have that as an 8x10." So now you go back to your JPG and for a print you need to enlarge then sharpen your image. In every world I live in (and some think it's more than one, or maybe that's just in my head ) using a RAW file would be much better than any JPG.
I think the real point here is, not that your workflow is more or less, or even knowing your camera, it is the ability to smartly archive and preserve the moment you are trying to capture with the most fidelity possible. This is the only way you can then manipulate the image properly to adjust it to any version of the reality your memory allows, at any point in the future.
camera, dslr, jpeg, k10d, photography, quality
Nature Don't Feck With Me! donallison13 Post Your Photos! 1 11-02-2010 06:27 PM
HI,I'm Don Dryer d-dryer Welcomes and Introductions 3 11-10-2009 07:47 PM
K10D JPEGs-I was pleasantly surprised! Rmpjr7 Pentax DSLR Discussion 23 04-02-2009 02:10 PM
Don in Louisville craftsmansky Welcomes and Introductions 3 10-28-2007 04:21 AM
Good quality JPEGs from K10D-try this *isteve Pentax DSLR Discussion 2 04-18-2007 08:18 AM
All times are GMT -7. The time now is 11:56 PM. | See also: NikonForums.com, part of our network of photo forums!
