01-13-2009, 10:27 AM   #1
K20D-In camera toning adjustments
In general I like that the K20D has so many available adjustments to color or b/w photographs. With monochome, I especially like the toning adjustment where you can not only use a filter color, but adjust the tone of that color either cool or warm.
I find the toning adjustments a bit big in steps, but I'm able to work around it just fine. Experimenting with them has brought some nice results imo. I found a particular setting of both color filter in b/w, and a toning adjustment combination I like and will be using. Nothing big here on the shot at all, just an example. I underexposed the shot a bit to accentuate the vignetting at little at 55mm on the kit lens (which is actually pretty well controlled at f5.6).
Here are a couple of shots for examples. Again, it is just the feel of the tone/color I like and have a use for now for a project I have coming up. It isn't quite sepia, having less red tone to it overall that I can see, but I gues would best qualify as Sepia if you wanted to label it.
This is shot at f3.5 which has more vignetting.
adjustment, adjustments, b/w, bit, camera, color, dslr, filter, photography, shot, tone
Suggestions for Camera Adjustments JamesD Photographic Technique 4 10-03-2009 04:54 PM
Split Toning presets for Lightroom xs400 Digital Processing, Software, and Printing 2 09-25-2009 06:45 AM
Adventures in Split Toning. metroeloise Post Your Photos! 7 12-05-2008 04:35 PM
K20D AF adjustments ManuH Pentax DSLR Discussion 14 09-11-2008 02:47 PM
K20D - AF adjustments - for all and for one - cumulative or not ? deejjjaaaa Pentax DSLR Discussion 7 08-12-2008 02:45 AM
All times are GMT -7. The time now is 03:27 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
