01-13-2009, 12:50 PM   #1
Dirty viewfinder problem?
Hey guys, I just realized that my K10D seems to have dust or lint or something strange on the viewfinder. It's not on the piece of glass I look through - I cleaned that. And it also doesn't show up in pictures. I can't imagine how it got there, but is there any way I can fix it? Thanks!
01-13-2009, 12:53 PM   #2
Probably just on your focusing screen. Use a blower to get rid of it.
01-13-2009, 01:05 PM   #3
Hi there, I just took the lens off and it appears to be on the little thing behind the mirror? How should I get to that? Just want to make sure I do it right. Not sure how I got anything in there in the first place since I haven't taken the lens off in a while...
01-13-2009, 01:20 PM   #4
look in the manual for "sensor cleaning"...
01-13-2009, 01:29 PM   #5
HMMMMMMMMMM
The little thing behind the mirror is the sensor. Which means you have dust on the sensor. Use a blower and with the camera turned upside down give it a few blows. If it is still there try a Pec-pad (soft non abrasive dry wipe) and lightly wipe it over the sensor in the same upside down position. If that doesn't work there are some good sensor cleaners on the market, but for the little it would cost to have it professionally cleaned I would go that route. At least if anything happens they are responsible to fix or replace it.
Dust can get in at anytime you change the lens. the best way to change lenses is to point the lens to the ground and remove it and replace it with another lens the same way. This way there is still a chance of dust getting in but not as much.
The other thing here is you have the K10 which has a dust removal system built in. try that first and then try the rest.
01-13-2009, 01:34 PM   #6
QuoteOriginally posted by blank Quote
If you're seeing it in the viewfinder and not on the pictures the dust isn't on the sensor. You might have dust there too, but it's not causing it to show in the viewfinder.
01-13-2009, 01:42 PM   #7
Marc Sabatella's Avatar
If there is dust in the viewfinder but not on the picture, opening up the camera long enough to try to clean the viewfinder is likely to give you the opposite problem a clean viewfiner but dust on the sensor, and hence on the pictures. I say leave well enough alone if you don't knwo exactly what you are doing.
camera, dslr, photography, viewfinder
K-x viewfinder problem ?? eastbay Troubleshooting and Beginner Help 2 11-05-2010 09:01 PM
K200D viewfinder problem snofox Pentax DSLR Discussion 8 01-26-2010 07:48 AM
K-7 Viewfinder and Mirror or CCD problem Wildspirit Pentax DSLR Discussion 2 08-18-2009 06:41 AM
Dirty Viewfinder Scott_the_Artist Troubleshooting and Beginner Help 8 08-14-2009 10:26 PM
Dirty viewfinder kent Troubleshooting and Beginner Help 10 07-18-2009 12:18 AM
All times are GMT -7. The time now is 02:17 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
