Originally posted by Jewelltrail Pentax Poke: I saw your test for metering with the Katzeye, but was hoping to have a response from you on these words, taken directly from the Katzeye site:
"•Center Weighted Average (CWA) Metering Mode: Our testing showed CWA metering mode to be accurate for all AF lenses having a maximum aperture of f5.6 or larger (lower f number).
•Evaluative Metering Mode: Our testing showed evaluative metering mode to be accurate for all AF lenses having a maximum aperture of f5.6 or larger (lower f number).
•Spot Metering Mode: Our testing showed spot metering mode to be within factory tolerance for all AF lenses having a maximum aperture of f2.0 or larger (lower f number). Lenses having a maximum aperture smaller than f2.0 (lager f number) will show a significant shift toward increased exposure, with the shift increasing for lenses with smaller maximum apertures. Spot metering mode is NOT RECOMMENDED when using a split prism focusing screen with lenses slower than f2.0. However, if spot mode must be used, it is strongly advised to first take a test shot, check the histogram, and adjust exposure compensation as required."
I rely heavily upon spot metering.
Thanks for the kind words Ernest.
I agree with all of the bullet points above. I am just not seeing major problems with metering of any type. I just played around with it some more on my FA35, and all the metering modes work well. I don't do any "stop down" metering myself, but in the test steve just had me run, I am just not seeing huge problems with my screen. There is a small shift in the histogram from f/2 to f/16 with the stop down spot metering, but to me it is not a big deal in the tests I have done so far. If it were consistent I would just shift the EV. Maybe there really is a difference in metering between standard Katz and Optibrite Katz. I wish I could be more helpful in this regard. I don't know if my tests apply to lenses that you might be using.
Without question, this screen will be helpful to anyone with the type of lenses I have below. As you see, I do not have any pure manual lenses, so I can't comment on those. Steve may be the one to consult in that regard. I suspect though, that if your lenses are working with the split screen you mentioned, that they would work even better with the Katz.
