PentaxPoke:
I finished reading this very informative thread of yours and want to congrat you for the fine work.
Now, I have questions!!
(That will give you no choice to answer because I just complimented you!
I use both the K20D and the K7; I know for sure that the K7 can now be fitted with Katzeye screens).
My vision not being the best, I have long considered a visual aid for fine focusing, especially when it comes to fully manual lenses with large apertures (f1.2, f1.4 ...) and this seems to be the best option.
- Is the Katzeye screen only good for manual focus lenses or should it also work well when "quick shifting" a DA* lens?
- If it can be used with DA* lenses, does one have to switch the lens and the camera to manual?
- Is it going to be a hindrance when using it with AF only lenses? I am thinking of my old FA50/1.4.
- Would you recommend, in my particular case of bad vision, the OptiBrite and Plus treatment? I am told that the Opti Brite is only for making the screen "brighter" outside of the central split screen and circular prism, and doesn't have any effect of the focus itself.
Lots of questions, but I just don't know what to expect if I fit the cameras I own with the Katzeye screens. I assume it should help me but it would be nice to have an opinion based on the information herein.
Cheers!
JP
P.S.: the lenses I use are:
DA*300/4 ... 60% of the time, with/without a 1.4x TC or a 1.7X TC.
DA*16-50/2.8; Carl-Zeiss 85/1.4 (manual lens); Cosina 55/1.2 (manual lens)
Tamron 90/2.8 Macro (AF/manual) and a Tamron 70-200/2.8 (AF/manual - old type, non-HSM version)
