02-23-2009, 03:45 AM   #16
roentarre's Avatar
Moved to DSLR section.
02-23-2009, 05:06 AM   #17
wildman's Avatar
QuoteOriginally posted by Vormulac Quote
so you get a more eyeball-like overall scene, with detail in each area.
I'm very much a purist when it comes to digital tricks but about a month ago I tried the D range function on the K20D.
Conclusion: It works.
I'm strictly an available light shooter and for this kind of shooting it definitely has it's place.
Following is a shot taken with the cat sitting in a south facing window with strong sun light coming in window casting deep shadows.
Anyway the long and short of it is that for this kind of lighting, using the D range function, definitely gives a more accurate, closer to what the eyeball actually sees at the time the shutter is released, tonal range than without it in my opinion.
02-23-2009, 07:06 AM   #18
Ben_Edict's Avatar
QuoteOriginally posted by wildman Quote
That reflects basically my own experience. I only use RAW, never shoot jpgs. But the D Range feature does work. Whether it is only embedded info which is applied by the RAW converter (LR2, in my case) or whether it is actually applied in camera, does not really count, though I tend to say, it is done in-camera as otherwise the shifting to ISO200 as a minimum would not be necessary.
I find, that I have to be careful, when to use D Range, as I found, when first trying this option, that the mid-tone contrast can get excessively low, with D Range. So low, in fact, that I couldn't bring it back to a reasonably steep curve, without runnig into clipping. So I am very careful, when to use it and more often, not to use it.
Ben
camera, dslr, love, photography
All times are GMT -7. The time now is 12:22 AM. | See also: NikonForums.com, part of our network of photo forums!
