Originally posted by greenboy Seems like a toss-up. Based on the responses in this thread, it just comes down to priorities. Please correct me if I have any mistaken assumptions in my summary as I try to make a decision on which camera to get.
*ist D/DS: Pros are better metering, red focus indicator, lower MP won't expose the shortcomings of legacy lens (although this is debated between two users), lower cost ($175 to $225 used). Cons are there is no shake reduction and lower MP (some say higher is better?).
K2000: Pros are newer camera, shake reduction, reasonable cost ($350 new with kit lens). Cons are no red focus indicator and metering not as good as the *ist D/DS. Same debate regarding the pros/cons for having more MP.
K10D/K20D: Pros are shake reduction, red focus indicator, weather sealed, more professional functions. Cons are metering not as good as the *ist D/DS, and cost ($600 for the K20D, or $300 for an used K10D).
Does that sound about right? At this point, I think I'm narrowing my choices to the *ist DS and K10D. Anymore suggestions would be greatly appreciated. Thanks.
you left out the most important point of an *istD, TTL flash metering. If you are going to use legacy lenses a lot, you may want to have flash also. A K10D only gives you manual flash (built it) or either manual or "auto" on external units.
An *istD gives you true TTL flash with both the in camera and external flashes that support TTL.
that outweighs all else in my consideration.
also don't forget the ability to dial in exposure compendation in manual mode, something the K10D lacks.
