Originally posted by gibikote I tried it today, but the lenses are not focussing. I double checked that the switch is on AF, and even reset all custom selections to default.
Not sure whether AF settings such as the following are reset: One can, e.g., set the OK button to enable focus. Pressing the shutter button halfway then won't activate the AF but only pressing the OK button will.
Make sure it is none of this.
Originally posted by gibikote the exposure continues and I end up with a blurred image.
Normally, with AF activated the camera shouldn't take a picture unless it detects something in focus.
Is AF set to AF-S?
You could also try to look at the images of your friend and see whether they were taken with AF or manual focus. The PhotoME program can read the EXIF data of images and lets you know.
Hope that helps.
