Originally posted by RiceHigh What you have seen are all normal. The K20D is probably the most "hot" DSLR ever made on Earth.
I used to agree with you based on DPR's findings that the firmware fix didn't get rid of all the hotpixels because they move around unlike other sensors.
However, after running the "map pixel" thing, I haven't seen any, and I tested it quite a bit. If you want to know how OCD I am about testing this stuff, look at the Tamron 28-75 tests I did looking for a good copy of it
I tested the K20D on a tripod at ISO100-1600, did handheld tests, underexposed, overexposed, did 30sec exposure tests, and then pixel peeped the images. Before running the map pixel thing, I saw the hotpixels move around, change shape, get worse w/ higher ISO, etc. so I knew what I was looking for.
Hope that makes it into your blog...
