Originally posted by Alfisti Well hang on, we're being a bit unhelpful. f/4 is about right as compared to f/8,
sweet spot for both lenses. The user has a right to compare the gear.
Do us a favour, set up a flat target (most use brick walls) and set up a tripod, make sure it's square (this is vital).
Fire off a few frames and re-sample the images to the same size (downsample the largest file to match the smaller one) then cut a crop from the centre at 100% magnification.
Here is an example i did recently with an unideal subject but you get the drift ....
D80 (10mp)
K100D (6mp)
Off topic, but the D80 has some serious noise issues! That ISO 800 shot looked like ISO 3200 when I first saw it!
On topic, if you properly focused on the shot, I think there might be something wrong with your lens... good luck!
