Originally posted by kenyee 247nino: did you still need the LED aux light if you used a Pentax flash w/ the built in AF lamp?
Only in situations when I'd shoot against the club lighting and faces wouldnt have enough light reflecting back to me. The spot beams on the flashes are actually pretty accurate!
when I shoot slower than 1/15, the light is bright enough to change the color of the images, so I try to keep it off, but when I need it, I just correct WB later. OR I turn it on to focus, turn it off while keeping the shutter half pressed, recompose my shot, and then full press.
Another trick when shooting in darkness, with no other flashlights or ambient light to help focus, and for some reason you have an assistant with you and you're working at night or in the dark; my assistant held my cellphone (AT&T TILT with the LCD on a bright screen) next to my subject's eyes or whatever focal point I'd choose, I'd focus on the phone's screen then recompose.
