01-22-2009, 09:21 AM   #1
quenched's Avatar
THE SEXY PEOPLE and FLASH ISSUES
I have recently been shooting in a local nightclub, i used the k20d there for the first time last night.
It took me a little while to get the settings to work, i was having lots of very soft focus issues and hunting. Prob due to the F4 16-45 too.
Anyway it appears the on board flash is casting a blob shadow in many of the shots, i dont normally shoot flash and prefer the fast primes when shooting gigs but the club environment needs a zoom honestly.
Anyway Q's are this.
Has anyone else experienced the shadow i speak of?
Does Pentax have a flash set up that is designed especially automated for their cameras or will the old (but very good) Sunpak i have do the job?
IF ANYONE HAS SOME TIPS FOR SHOOTING IN LOW LIGHT WITH THE PENTAX K20 THAT IS UNIQUE/SPECIFIC TO THE MODEL AS OPPOSED TO A GENERAL ISSUE I WOULD VERY MUCH APPRECIATE IT.
Also does the IS system effect IQ if it is on yet there is no camera shake (i have a very steady hand but shoot in very bumpy environments often)
THIS SEEMS LIKE A GREAT LITTLE BODY SO FAR AND IM ENJOYING 'THE CURVE'
Thank You all once more.
01-22-2009, 09:26 AM   #2
I guess the quick question is what focal length are you shooting when using the 16-45? What you might be seeing is being caused by you shooting at a focal length too wide for the on-board flash. Post a couple examples please.
01-22-2009, 09:28 AM   #3
forensicscientist's Avatar
Could "the blob shadow" be from the lens hood?
01-22-2009, 09:29 AM   #4
Venturi's Avatar
Are you referring to a half-moon-ish shadow on the bottom of your shots with the onboard flash? If so, it's likely the lens hood of the 16-45 blocking the flash. Take it off when shooting with flash, especially at wide angle.
01-22-2009, 09:30 AM   #5
Venturi's Avatar
LOL talk about pouncing a thread. 3 replies in 3min
01-22-2009, 09:37 AM   #6
Blue's Avatar
You can experiment with the ISO settings when shooting in low light as well.
01-22-2009, 09:37 AM   #7
The on board flash is a waste of time, IMO. As a last resort, OK, but anything else I'm afraid isn't worth the trouble. If money is an issue, I can understand, but if you can afford it, I would find a decent used flash and a cheap wireless trigger.
The dead spot you're referring to is the end of the lens blocking part of the flash, especially if you've got the barrel of the lens extended.
You should try to avoid ANY flash that is too close the lens, if you can.
01-22-2009, 09:41 AM   #8
I've got the 16-45mm zoom and I'm very happy with it. Like most lenses in a dark place, it WILL hunt for a focus point. But I've had decent success with the lens in clubs:
Flash As Stage Lighting - a set on Flickr
01-22-2009, 09:57 AM   #9
Lowell Goudge's Avatar
a good dedicated hot shoe flash with focus assist will help hunting, because all cameras have trouble in low light not only pentax.
Faster lens also will help hunting,
the hot shoe flash , as others have mentioned will eliminate the problem of a flash shadow caused by the lens hood.
but if yo have a K20, forget the flash, get a faster lens and shoot high ISO without flash, It is a lot of fun
01-22-2009, 09:59 AM   #10
quenched's Avatar
why a wireless trigger?
whats wrong with hotshoe firing? (excuse my ignorance with portable flash)
Do pentax flashes have the same specialised interrelationship with the bodies as say Canon do?
01-22-2009, 10:01 AM   #11
quenched's Avatar
Cant post yet, still waiting on the cable to dump too my mac/pc.
Will i need to load anything on before i can?
Cheers
01-22-2009, 10:08 AM   #12
quenched's Avatar
Deaner, it seems like a great little lens so far.
The club is extremely dark in some corners. Normally i shoot full manual yet with f4 i just went shutter priority and left it wide open. What settings do you use generally? ie afs? tv? av? m? ISO?
My 30d would get ugly noise around 600 iso, what is true for the k20? im thinking around 1000 (?)
thank you everybody
01-22-2009, 10:15 AM   #13
quenched's Avatar
Lowell, i normally do. This joint is probably too dark for a 2.8. What ISO can you shoot up to sharply? what glass?
I will give the 1.4 sigma a crack in there when it arrives.
Cheers
PS anyone know a good simple site/thread for achieving professional results shooting flash?
01-22-2009, 12:03 PM   #14
247nino's Avatar
"here I am rock you like a hurricane" -the mooninites
QuoteOriginally posted by quenched Quote
Nice, I can answer your question and give some tips, this is a rarity because I usually suck.
I only experience that shadow using on board tiny flash and a lens with a big hood.
As far as flashes, its best to use a dedicated P-ttl flash, I'm scared to be firing other flashes mounted on my hotshoe.
strobist.org is a great BORING COMMUNITY, you can learn but you will get bored with the technical crap
onelightworkshop.com is much better but skip all of that and remember this when strobing/flashing
*EXPOSURE CONTROLS AMBIENT LIGHT
*APERTURE CONTROLS FLASH EXPOSURE
TIPS
heres my old setup
I say old because I cut down from using that
k20/grip, 16-50, 540/diffuser, led/bracket to
k10/grip, 18-55, 360/no diffuser, no led
and then finally to
k10/grip, 16-50, 360/fake omnibounce/with LED gaffer's taped to it
with my journey through the different setups I
*learned how to control p-ttl with the diffuser
*learned that p-ttl sucks anyway for a nightclub
*disliked how big my rig looked; its intimitdating!
*I only turn the LED on when I absolutely need it
*decided that 2mp in jpeg is the way to go since I resize my photos to long edge 1200pixels
*and I dont take the k20d to the club anymore because the K10 is just as awesome
*shooting with the 360 flash in manual on 1/8 power and using apertures from f5.0-f7.1 gives me nice lighting from 3-8ft which is usually my distance from the subjects/club goers
*I use the center focus selector and I focus on faces and recompose with the shutter half pressed
some don'ts at the club -
dont shoot at f2.8 or wider
SR
you can see that I move my hands quite a lot in my photos, SR on or off it doesnt matter once you start controlling that flash whether its on or off the camera, you will get sharp photos.
about fast lenses... if you can control your flash(aperture +power)/ambient light(exposure) then all a fast lens does for you is make it easier to focus and hunt less because it will focus with the lens wide open at 2.8 to let it more light
the kit lens gives me these @ f4.0:
and the 16-50 gives me these @ f4.0 and higher:
01-22-2009, 12:12 PM   #15
QuoteOriginally posted by 247nino Quote
Your fake omnibounce intrigues me good sir. Please post a picture and share!
camera, dslr, flash, issues, pentax, photography, shadow
People Outdoor flash use - people jpzk Photo Critique 18 10-11-2010 04:13 PM
Having flash issues. HeavyD Flashes, Lighting, and Studio 33 03-28-2010 05:39 PM
Flash Issues Tomzee93 Troubleshooting and Beginner Help 1 01-08-2010 12:03 AM
Shot random people outside with a flash? Zakovva Photographic Technique 21 09-02-2009 02:25 PM
Flash Issues wmaher2 Flashes, Lighting, and Studio 2 07-14-2008 12:55 PM
All times are GMT -7. The time now is 03:19 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
