01-23-2009, 04:59 AM   #1
OK..dumb-assed question re manual lenses
What setting do I use when I use an old manual lens on my K10D? I know that I switch to manual focus....but which other setting? P, Sv, Tv, Av, TAv or M? Or none of these? :-)
01-23-2009, 05:07 AM   #2
ftpaddict's Avatar
QuoteOriginally posted by Darius4522 Quote
You could use the K10D in Av or M, though I'm sure the camera won't lock up if you attempt to use any of the other modes.
Don't forget to enable the correct settings in the custom menu to allow use of non-A lenses.
01-23-2009, 05:07 AM   #3
Mike Cash's Avatar
That depends on what sort of old manual lens you are talking about. Is it a K-mount or screwmount? If K-mount, use M mode and press the green button to meter. If screwmount, you can do the same or you can shoot in Av mode.
01-23-2009, 05:09 AM   #4
you can shoot in Av with K-mount M lenses too, but the lens will stay wide-open all the time.
01-23-2009, 05:22 AM   #5
Lowell Goudge's Avatar
a simple reminder
before anything else, don't forget to go into the menu and custom functions and set "use apature ring"
01-23-2009, 03:06 PM   #6
Thanks, everyone. As per usual everyone is very helpful!
01-23-2009, 03:21 PM   #7
Moderator PEG Judges
Kerrowdown's Avatar
It would appear so except me, who did not reply quick enough.
01-23-2009, 05:46 PM   #8
SteveM's Avatar
The apature blades on a k mount manual lens won't stay wide open if you set the apature ring to a higher f stop....the apature blades narrow briefly when the shot is taken.
01-23-2009, 11:21 PM   #9
You can get great results, but you have to do everything manually.
It's good for you.
Put your camera on M and start feeling your way around.
Pretend your camera is a K1000.
camera, dslr, photography
a dumb question about lenses kyricom Troubleshooting and Beginner Help 5 10-26-2010 04:21 PM
Dumb noobie question on M42 vs. k mount lenses... speedoo Pentax SLR Lens Discussion 13 01-28-2009 04:19 PM
Question re manual lenses Clem Nichols Pentax SLR Lens Discussion 10 09-25-2007 04:11 AM
Dumb question, I know, re K10D and old lenses Darius4522 Pentax DSLR Discussion 3 09-24-2007 04:00 PM
Manual exposure with K10D - dumb question The Pentax Hammer Pentax DSLR Discussion 30 06-24-2007 01:46 PM
All times are GMT -7. The time now is 06:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
