01-23-2009, 05:51 PM   #1
K20D, Yellow tint in middle of frame
Hi guys,
just arrived here and would like to ask for your comment. I purchased a K20d and took a row of frames particulaly at higher ISO as 1600, 3200, 6400, as I like in principle the behaviour of the camera at these settings. The noise looks very much like analog film grain and I saw impressive prints in A4 (about letter format) and half of that from a unit that I unfortunately do not own myself. The one I got produced a strange noise in different situations, especially visible when pointing it at a white wall. While upper and lower portion looke blueish or purpleish, the center of a frame showed a yellow tint. This was visible down to even 100 ASA when looking closely enough in pictureds other than what I enclosed here for reference. It most likely appeared at White Balance set to tungsten, but also under other settings. High ISO noise reduction as well as any other setting, such as contrast, sharpering, did not contribute. May I ask you whether you had any experience like this yourself. Could you make a shot as mentioned and see what happens at your end? I got the camera replaced once and will return it another time as I have seen the model behave far better. How likely is it to get a "good" sample? Pentax doesn't seem to be aware of the phenomenom yet, but promised to look into it.
Thanks for comments and best regards,
Kai from Berlin, Germany
01-23-2009, 09:50 PM   #2
What light source did you use?
01-24-2009, 05:02 AM   #3
that was an energy saving lamp. thought the cast of light onto the wall might be causing that, so made a shot of the same area holding the camera upright, but that didn't make a difference. to me it looks like the sensitivity of the sensor itself is less than in the center. shots of dark surroundings show blue dotted noise there while the center still is almost black with less noise.
k.
01-24-2009, 08:18 AM   #4
QuoteOriginally posted by kasv Quote
k.
Did you shoot at a shutter speed higher than 1/60th second then? Or even much higher?
01-24-2009, 09:53 AM   #5
mer
It is the lamp that's causing it .
01-24-2009, 12:51 PM   #6
QuoteOriginally posted by RiceHigh Quote
1/60th. here the complete EXIF:
Make - PENTAX Corporation
Model - PENTAX K20D
Orientation - Top left
XResolution - 72
YResolution - 72
ResolutionUnit - Inch
Software - K20D Ver 1.00
DateTime - 2009:01:17 20:09:54
YCbCrPositioning - Co-Sited
ExifOffset - 598
ExposureTime - 1/60 seconds
FNumber - 4.50
ExposureProgram - Manual control
ISOSpeedRatings - 6400
ExifVersion - 0221
DateTimeOriginal - 2009:01:17 20:09:54
DateTimeDigitized - 2009:01:17 20:09:54
ComponentsConfiguration - YCbCr
ExposureBiasValue - 0.00
MeteringMode - Multi-segment
Flash - Not fired, compulsory flash mode
FocalLength - 0.00 mm
FlashPixVersion - 0100
ColorSpace - sRGB
ExifImageWidth - 1200
ExifImageHeight - 797
InteroperabilityOffset - 54284
SensingMethod - One-chip color area sensor
FileSource - Other
SceneType - Other
CustomRendered - Normal process
ExposureMode - Manual
White Balance - Manual
FocalLengthIn35mmFilm - 0 mm
SceneCaptureType - Standard
Contrast - Hard
Saturation - Normal
Sharpness - Hard
SubjectDistanceRange - Distant view
Maker Note (Vendor): -
Mode - Auto
Quality - 5
ISO - 24
White Balance - Tungsten
Thumbnail: -
Compression - 6 (JPG)
XResolution - 72
YResolution - 72
JpegIFOffset - 54408
JpegIFByteCount - 5615
k.
01-24-2009, 06:03 PM   #7
QuoteOriginally posted by mer Quote
Possibly..
01-24-2009, 06:06 PM   #8
Model - PENTAX K20D
XResolution - 72
YResolution - 72
ExifOffset - 598
FNumber - 4.50
In order to confirm your source of problem, try increasing the shutter speed and to see if the vertical width of the yellow band would decrease. Try one (far) below 1/180s and one (far) above 1/180s if possible.
Please post back these pics when done. I guess I could isolate the problem this time and tell you something if so.
01-24-2009, 10:27 PM   #9
Canada_Rockies's Avatar
k.
By an energy saving lamp, I am assuming you are talking about fluorescent lighting. Although our eyes think the light is continuous, it is not, it flickers at the frequency of the source electrical feed - 60 Hz in North America mostly, 50 Hz in Europe. A good general rule for snapping under these conditions is to use a shutter speed that is longer than two cycles of the lamp. This also applies to television screens - in which case it is double the scan rate that you want to use. Rice High got the speed problem backwards. You want to go slower, not faster.
01-25-2009, 03:07 AM   #10
well, considered that as well. yet, shot the same area with k100d super at 3200 iso and the result was even; color tint depending on the wb of course, yet the whole area was covered and i found no blueish or other differntly colored stripe on top or bottom or elsewhere. never came across that or similar behaviour durign some 10000 shots with k100ds od ist dl in the past. so there really must be sth special to k20d. tried 4 units now plus one samsung g20 and all showed the same yellowish center tint.
if you had a k20d pls. try and compare and let me see you results.
k.
01-25-2009, 06:09 AM   #11
I think it is not the yellow, but the blue tint. I have that appearing at high isos and this looks very similar. Read more about that from here:
https://www.pentaxforums.com/forums/pentax-dslr-discussion/47584-strange-k20d...-patterns.html
01-25-2009, 04:36 PM   #12
first of all thanks for all your contributions. addressing what mer, ricehigh and can. rockies said, took the same "measurement" at different shutterspeeds.
the unit is in fact a different one thanks to my friendly dealer who replaced it another time. this seems to be less prone to the issue, thus making it harder to illustrate. but see yourself.
first a shot in the shade of daylight, i.e. no lamp on other than the sun. this 0002. 0015 is a shot of the bottom of a black frying pant osee how black black is reproduced at that ISO. Looks quite even to me compared to what I saw before. now the wall shots. surprisingly, all shutterspeeds looked about the same as 0049, which appears quite even to me. at most a little trace of what i observed with the other models.
chose a different object that was more likely to cause the issue. see the results enclosed with this and following msg.
cheers, kai
01-25-2009, 04:40 PM   #13
to me all this looks less bad than before. however, see the rest here.
01-25-2009, 04:55 PM   #14
ok, which is which: (all 6400ISO)
1st mail:
0049 (1/60, energy saving lamp)
0015 (dark frame; frying pan)
0002 (no artificial light; daylight shadow)
1/125, f4
1/90, f6.7
2nd mail:
1/90, f8
1/45, f11
1/15, f16
1/8, f22
01-25-2009, 05:03 PM   #15
Wheatfield's Avatar
1st mail:
1/125, f4
1/90, f6.7
2nd mail:
1/90, f8
1/45, f11
1/15, f16
1/8, f22
Ummm, you are shooting at ISO 6400 and your wondering about why you are getting noise?
Get used to it instead.
camera, dslr, frame, iso, k20d, noise, photography, settings
Yellow Tint chilihead Troubleshooting and Beginner Help 9 10-18-2009 03:41 PM
K20D RAW tint corrections jeffkrol Pentax DSLR Discussion 0 08-20-2009 10:39 AM
K100 Super Manual Lens Yellow Tint/Overexposed??? Grzldvt Pentax SLR Lens Discussion 8 06-09-2009 05:13 PM
what's causing this weird yellow tint ? chiem Pentax DSLR Discussion 17 03-11-2009 06:43 AM
Green spot in the middle of the frame elijahkagan Pentax SLR Lens Discussion 9 03-06-2008 10:49 AM
All times are GMT -7. The time now is 11:02 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
