Originally posted by axl Does it mean you keep all your RAWs?
boy if I did it I'd have wall full of CDs/DVDs with archives or I'd have to buy new HDD every 6 months...
BR
A compressed RAW file (can be generated in camera or via Adobe DNG Converter) is much smaller than a full resolution TIFF file of the same image, and not that much bigger than a JPEG of full resolution and high quality. So if you're in the habit of converting all your RAW files to TIFF, you're taking up *more* space, and even if you convert to JPEG, you are probably saving only maybe 30% at most in file size over the RAW file.
Of course, if you were thinking of keeping both the RAW *and* a high resolution conversion, that would more double the space requirements. But if you keep your RAW files and use modern RAW processing software that lets you work with your RAW images directly, there is no reason to generate the high resolution version of most of your files. You can keep the original RAW file and use that for your full resolution needs, or perhaps generate a full resolution TIFF to send to a print service on an as-needed basis, and then delete it when you're done. As a general rule, I generate only medium-resolution JPEG's (good enough for web use and a 4x6 print) of my files, and only for the ones I identify as "keepers" - maybe 30% of the shots I take). These take next to no space.
So while converting everything to high resolution JPEG and deleting the RAW files might mean your storage cost is around 6-7MB per image on average for a 10MB camera, keeping the RAW and only the medium resolution JPEG of the keepers means around 9-10MB per image on average. Hardly a difference to lose sleep over.
