Originally posted by jonpitt I recently purchased a K200d (with 18-50mm and 50-200mm kit lenses) and have enjoyed both starting to learn to use it and the quality of photos (mostly!) produced.
Welcome to the club!
Originally posted by jonpitt However, I would like some advice re image naming: when first used (up to about 200 images), images had names of the form IMGP0122. Without any alteration to settings per menu, subsequent image names have taken the form _IGP0637.
The number part is consistent with actual numbers of images recorded.
I have tried reformatting the SD card (Sandisk 4Gb Extreme III) and also resetting to 'factory defaults' for camera settings, but the image naming error persists.
This has nothing to do with the card. I suspect you've changed the Colour space.
Page 155 of the manual has the answer:
- sRGB files have the format IMGPxxxx.JPG (or .PEF or .DNG)
Originally posted by jonpitt Has any one else encountered this problem? If so, were you able to correct it (and how?). More particularly, should I be concerned enough to send the camera in for inspection....?
Not a problem at all - just choose your colour space. Your camera is fine!
There is a bit of
discussion about as to which is better (or worse). Its suggested that sRGB is better for web output, whilst AdobeRGB is better for printing with a wide colour space.
Hope that helps.....
