02-02-2009, 11:44 AM   #16
Marc Sabatella's Avatar
QuoteOriginally posted by indytax Quote
I'm also trying to understand the limitations of P-TTL with older lenses before I dive into a Pentax DSLR system.
The limitation is, the flash fires full power. If your particular unit has a manual override unit, great, you can use that, and of course you can use the guide number formula to set an aperture. And nothing the camera does could prevent auto-flash (ie, sensor on the flash unit) from working.
So basically, using a 70's lens puts you back into the 70's with regard to flash, too :-)
camera, dg, dg lens, dslr, k20d, lens, photography
K20D, K7, Kx, or Lens? SLRPhotography Pentax DSLR Discussion 0 11-16-2009 06:18 PM
Best budget tripod for a K20D kit lens and a Tamron 70-300mm lens. shaolin95 Pentax Camera and Field Accessories 13 08-29-2009 11:53 AM
In Canada: Summer Rebates for K20d or K20d plus lens Pentaxtic Pentax DSLR Discussion 1 07-17-2009 11:34 AM
Lens to replace k20d kit lens? kenhreed Troubleshooting and Beginner Help 19 07-13-2009 01:56 PM
For Sale - Sold: K20D, 16x45mm lens, 50mm (manual) lens, FGZ540 flash pentaxshooter Sold Items 0 09-21-2008 03:21 PM
All times are GMT -7. The time now is 08:07 AM. | See also: NikonForums.com, part of our network of photo forums!
