03-26-2007, 09:49 AM   #1
Bad moire pattern problem from K10d. Fixable?
Wow I was really surprised to see several examples of very bad moire patterns when shot in Raw PEF and converted to DNG. Can't seem to excape it. Any ideas?
Can it be fixed? How do I avoid this in the future?
Thanks.
PENTAX K10D  Photo
03-26-2007, 02:06 PM   #2
slip's Avatar
QuoteOriginally posted by Photomy Quote
Thanks.
Is it there before you convert it?
03-26-2007, 03:47 PM   #3
QuoteOriginally posted by slipchuck Quote
I am not sure what you mean. If you mean does it show up when I bring the PEF file directly into PS (CS2), and do not use the Adobe DNG convertor program, then yes it is still there. My copy of Pentax Photo Lab does not seem to work so I use PS only. I did not take any JPEGs to compare with.
There were several other shots with the same blue knit shirt that were even worse. I had no idea that a camera with an AA filter installed could have moire this bad at high resolution. Hopefully this shirt just happened to have just the right knit pattern frequency?
03-26-2007, 06:01 PM   #4
jeffkrol's Avatar
As far as I know, the strength of the AA filter is inversly proportional to the amount of moire. Stronger AA, less moire. At least generally speaking.
Resolution is also inversly proportional to the strength of the AA filter..
My D hardly ever exhibits moire. The critics say it's resolution is lower than most 6mp DSLR's. Pick your poison......
03-26-2007, 07:26 PM   #5
slip's Avatar
that is weird.
One long shot to try is......
set your color space output to Adobe RGB 1998 in your camera
If you are in bright color mode, then switch it to natural mode.
I am taking a stab in the dark with those idea, but worth a try.
otherwise, I did not read in detail about other camera's with the same problem, but if you do a search a few nikon forums have a solution posted for nikon cameras, but not sure if the idea could be transfered to the K10
otherwise you will have to post process in photoshop to get rid of it
good luck and let us know how you solve the problem if you can
cheers
randy
03-26-2007, 08:14 PM   #6
Actually, most cameras would exhibit moire under the right circumstances. This is a fact of life for digital sensors with photo sites aligned in a regular pattern. The only way to avoid them is to blur them out - i.e. AA filter; but you reduce the resolution in doing so. So it is always a compromise.
03-27-2007, 07:43 AM   #7
dbh
QuoteOriginally posted by nosnoop Quote
With subjects likely to produce the moire pattern, try a few brackets with slight camera tilts. You can straighten the shots later.
You can try adding some noise to the unprocessed image.
Make a few copies - add random noise to each, add them back together. You can mask out areas where increased detail needs to be retained.
Also Google "removing moire patterns with photoshop" for several step-by-step procedures.
dbh
camera, dslr, photography
Really bad kx problem..please help chopath Pentax DSLR Discussion 8 02-20-2010 05:35 PM
Fixable problem, or ignore it? foxglove Pentax DSLR Discussion 10 12-30-2009 09:27 AM
Pentax please REMOVE Anti-Aliasing on K-7 LCD illdefined Pentax DSLR Discussion 22 09-20-2009 02:44 PM
fixable sensor problem? slaw0710 Pentax DSLR Discussion 1 07-18-2009 03:09 PM
Aliasing on Resize wa5am Digital Processing, Software, and Printing 2 11-17-2008 08:20 AM
All times are GMT -7. The time now is 02:53 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
