03-26-2007, 08:33 PM   #1
Pentax raw files DNG & PEF and Wbal.
On the Adobe site Bruce Fraser wrote
"White balance. The white balance setting on the camera has no effect whatsoever on the captured pixels when you shoot raw—it’s simply recorded as a metadata tag in the raw file. Some raw converters can read this tag and apply it as the default white balance (which the user can then override if desired), while others may ignore it completely and analyze the image to determine white balance."
So do the DNG or PEF raw files coming from K10d record white balance setting metadata tag that can be read in CS2 and apply as default?
For me one of the biggest challenges is getting color exact without messing around. Pre-setting white balance really helps for JPEGS. I am somewhat confused if this same procedure helps for RAW files.
03-26-2007, 09:19 PM   #2
jfdavis58's Avatar
White Balance
QuoteOriginally posted by Photomy Quote
Yes the WB is a tag in the PEF/DNG; yes, it should be the 'as shot' menu item in ACR.
Capturing WB information when specifically saving images as PEF/DNG is a good starting point. It's applied to the JPEG previewed on the camera LCD if you have it set to show or you recall images for review. (And then in ACR as 'as shot'.)
balance, camera, default, dng, dslr, files, metadata, pef, pentax raw files, photography, tag
pef files rejected by Lightroom but dng ok Squeeze Pentax DSLR Discussion 5 02-24-2010 05:06 PM
RAW in Linux - PEF vs. DNG? danbob Digital Processing, Software, and Printing 55 07-26-2009 01:47 PM
RAW files? PEF versus DNG? rdrum76 Digital Processing, Software, and Printing 1 11-03-2008 11:59 AM
Pentax PEF vs DNG camera RAW Quality benjikan Pentax DSLR Discussion 3 03-22-2007 09:42 PM
RAW - PEF vs DNG??? rprii Pentax DSLR Discussion 7 12-11-2006 08:51 PM
All times are GMT -7. The time now is 01:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
