Pentax/Camera Marketplace |
Pentax Items for Sale |
Wanted Pentax Items |
Pentax Deals |
Deal Finder & Price Alerts |
Price Watch Forum |
My Marketplace Activity |
List a New Item |
Get seller access! |
Pentax Stores |
Pentax Retailer Map |
Pentax Photos |
Sample Photo Search |
Recent Photo Mosaic |
Today's Photos |
Free Photo Storage |
Member Photo Albums |
User Photo Gallery |
Exclusive Gallery |
Photo Community |
Photo Sharing Forum |
Critique Forum |
Official Photo Contests |
World Pentax Day Gallery |
World Pentax Day Photo Map |
Pentax Resources |
Articles and Tutorials |
Member-Submitted Articles |
Recommended Gear |
Firmware Update Guide |
Firmware Updates |
Pentax News |
Pentax Lens Databases |
Pentax Lens Reviews |
Pentax Lens Search |
Third-Party Lens Reviews |
Lens Compatibility |
Pentax Serial Number Database |
In-Depth Reviews |
SLR Lens Forum |
Sample Photo Archive |
Forum Discussions |
New Posts |
Today's Threads |
Photo Threads |
Recent Updates |
Today's Photos |
Quick Searches |
Unanswered Threads |
Recently Liked Posts |
Forum RSS Feed |
Go to Page... |
Search this Thread |
02-11-2009, 09:10 AM | #16 |
Highly reflective surface. | |
02-11-2009, 10:50 AM | #17 |
Veteran Member | I suppose you are saying that even in Av mode, Canon *would* have adjusted the auto-ISO or shutter speed after the pre-flash. That is, once it discovered the flash wasn't reaching, it would have changed the exposure settings it already settled on to allow the ambient light to correctly expose the scene. And maybe it would have - I've never used a Canon flash system. So in that sense, it might be more automatic in situations like this. Although I suspect there would be other situations where you could fool it, too. But really, I think fill flash *should* require a little thought - you should be in control of the ratio of ambient light to flash. At least, it seems you should want to be if you're considering using fill flash, as only you are aware of the specific aspects of the scene that require it's use to get the effect you want. What I would have done is use M mode, no auto ISO, so I am in control of everything. Of course I'm already shooting that way all the time, but even if I shot Av or P mode and used Auto ISO otherwise, I'd switch to manual operation for this. I'd think through what is the minimum ISO/aperture combination for the distance I am shooting and pick one that would allow the flash to reach. Then meter the scene - with the flash turned off - using Green button. Then slow down the shutter a stop or two because I am dealing with snow (or meter off something neutral in the first place). This would yield the shutter speed that would correctly meter the scene using ambient light. If I think the shutter speed is too slow to be usable, I increase ISO or aperture and speed up the shutter to compensate. Then, I decide how much fill I want, and speed up the shutter to underexpose the shot by that amount. Then switch on the flash and take the shot. Sound complicated? Sure, it's not point and shoot. But I know I'm less likely to be surprised by the camera's decisions, because the only decisions I am letting the camera make are ones I know it can handle (eg, choosing a shutter speed to expose the scene correctly given the available light, and choosing a flash output to expose the scene correctly given the current exposure settings and available light). BTW, I'm also not convinced fill flash would actually work too well here even had you been in range - any amount of light sufficient to brighten the birds would also have blown out the snow. Fill flash works to help even out uneven lighting, but it can't do anything about objects that are inherently different in brightness. I don't remember if anyone has pointed that out yet. That's actually a bigger problem here - the *best* you could have hoped for was a shot that looked identical to the one without flash, or one in which the snow was exposed *exactly* as if you had simply dialed in more exposure compensation (or done the equivalent in M mode, or metered off a grey card). |
02-13-2009, 06:10 AM | #18 |
Veteran Member Original Poster | I don't think that's quite true, although I admit I didn't follow that whole aspect of the discussion regarding how the Canon system differs from Pentax. But even with Pentax, this would have worked perfectly had you simply chosen an ISO high enough for the ambient light to have had any effect. Or chosen a larger aperture. Quote: But really, I think fill flash *should* require a little thought - you should be in control of the ratio of ambient light to flash. At least, it seems you should want to be if you're considering using fill flash, as only you are aware of the specific aspects of the scene that require it's use to get the effect you want. Quote: What I would have done is use M mode, no auto ISO, so I am in control of everything. Thank you for choosing Sigma products. There should be an upgrade available for this flash model to fix the problem. You would have to send it to Gentec International since you are located in Canada. Gentec International Quote: BTW, I'm also not convinced fill flash would actually work too well here even had you been in range - any amount of light sufficient to brighten the birds would also have blown out the snow. Fill flash works to help even out uneven lighting, but it can't do anything about objects that are inherently different in brightness. Sorry for the late response, I'm having a brutal month. February is crunch time at work and we just finished buying and selling houses, so I've been trying to stay off the internet. |
02-13-2009, 03:01 PM | #19 |
Veteran Member | I've gotten curious about this to do some experimentation to be sure what we are saying is not off-base. It isn't, and it is quite easy to prove. I do hope you read this, because this is some new information I have discovered and I think it will finally convince you. Feel free to follow along with your camera - you won't even need your Sigma to reproduce my results. I took my K200D, put it in Av mode, set aperture to f/8, set auto ISO to range from 100-800, and set my zoom to 200mm. The shutter speed selected by the camera always read 1/180, because the algorithm always seems to choose something around 1/focal_length. I scanned about my living room and watched the ISO change in the viewfinder as one might expect, showing that Auto ISO isn't totally disabled with flash (which was something I was otherwise beginning to suspect). Now, here's the interesting part. When I went outside and pointed at the house down the street, then *regardless* of what aperture I chose, the camera went with ISO 100. That's right, even at f/32, the camera wanted to go with ISO 100. That's what was displayed in the viewfinder, and that's what it used when I took the picture. Think that ended up being fast enough? No, *of course not*. I got a *completely black* frame at f/32, because the light outside wasn't *nearly* bright enough for a good exposure at ISO 100, f/32, and 1/180 shutter speed, and my little popup flash isn't *nearly* strong enough to light up the house across the street at that ISO and aperture. At f/8, I got an underexposed picture. Try it yourself and see that I'm not making this up. Now, *if* system were adjusting exposure parameters based on the actual light measured during the pre-flash, it would of course have noticed it had screwed up big time, and either raised ISO, lower the shutter speed, or both. But it did no such thing. It stubbornly held to the shutter speed and ISO it naively chose when it thought maybe the subject would turn out to be close enough for the flash to reach. This is completely consistent with what we've been saying all along: the flash system just isn't as smart as you want it to be. It's not a defect in the camera or flash - it's just how it is. The camera simply does *not* adjust any exposure parameter a result of the pre-flash. Whatever exposure parameters it is displaying in the viewfinder when you press the shutter, that's what it is going to use. The *only* thing it will change based on pre-flash is the flash output. No "fix" to your Sigma flash is going to change the fact that the camera is still going to choose ISO 100 for you when shooting birds outside, no matter how far away they are and no matter what aperture you select. Now, you may be wondering, why *did* the system choose ISO 100? That's a great question, and I don't know the answer. No matter what I tried, when the flash was popped up, it *always* chose ISO 100 any time there was a "decent" amount of light (eg, an amount of light that might hav resulted in an ISO 100 setting if I were in P mode). Indoors, it might choose ISO 200, 400, or 800 as it thought appropriate, but outdoors it *always* chose ISO 100. Apparently the algorithm measures the total amount of light and stops right there - it doesn't take into consideration shutter speed or aperture. Maybe it assumes the flash is infinitely powerful - I suppose it has no way of know just how powerful the flash is (after all you might have wireless slaves attached, too). But then, why go ahead and bump up the ISO indoors? I don't know; it's kind of a mystery, really. On the surface, though, it seems a pretty dumb algorithm. But this validates what I said earlier - it's another reason why I would never trust the camera to make the right decisions on matters like this where I have no insight whatsoever into what it is "thinking". I know it works pretty darned well as a center-weighted meter and can go a good job of setting shutter speed to my selected aperture and ISO or putting out the right amount of flash for my selected shutter speed, aperture, and ISO. So I'm perfectly OK with letting the camera make those decisions. Anything beyond that, move over - I'm taking control. Quote: I have Canon A720. I calll it a mini-dslr because it has all the controls of a dslr. Quote: The little Canon exposed the scene properly with its on-board flash Quote: yet you all are telling me the Pentax couldn't expose properly because the big Sigma flash didn't reach 25 feet. I accepted this answer, but it still smells funny IMO. Since we don't know the *exact* distance involved, or just how accurate Sigma is in stating their guide number, the only way to truly gauge this is to actually perform the experimented I suggested: set f/8, 1/180, and ISO 100 yourself in M mode (to remove the camera from the equation), force the Sigma to fire full power (assuming it has such a control), and see what you get. I don't find it hard at all to believe that exceeding the published specs by a few feet would result in underexposure. But again, if you test it, we can put the issue to rest. Quote: I disagree, and I still can't swallow that the Sigma doesn't have enough power to light a daylight scene at the limit of its Guide Number rating. Did the light hit a brick wall at the rated limit of 23 feet? Can we go with your original estimate of 30 feet? Dividing 175 by 30 yields 5.8. That's pretty close to 5.6. Meaning that you should expect to be able to do no better than one stop of underexposure with the flash. And that's one stop away from "correct" exposure - you actually wanted two stops of *over*exposure. Meaning, it's three stop below what you wanted. Available light has already been demonstrated to be 2.5 stops under your desired exposure at the settings chosen by the camera. So no, it shouldn't seem the least bit surprising that light from the flash (which is 3 stops too weak to give you the results you wanted at the select exposure settings), even combined with daylight (which is 2.5 stops too weak at those settings) wold not have been sufficient. But again, you needn't take my word for any of this - it is trivially simple to test if you can force the flash to fire full power. If you find it does indeed do better at full power than it did here, then I think you need to consider the possibility that reflections *did* play a role in that particular case, fooling the camera into dialing down the flash power just enough to make it that much less powerful. Quote: I'm not interested in manual mode with flash. A camera with P-TTL should be able to figure out a proper exposure. Quote: [i]Thank you for choosing Sigma products. There should be an upgrade available for this flash model to fix the problem. You would have to send it to Gentec International since you are located in Canada. Quote: Using fill flash is a very common technique in wildlife photography. The idea is to expose the subject, and if the sky, snow or water is overexposed, oh well. |
02-13-2009, 06:47 PM | #20 |
Best guess... again A bit more "thinkin".... photo 1 was at 1/160 f8 iso 100 mean is 109 photo 2 was at 1/200 f8 iso 640 mean is 212 http://www.libraw.org/articles/zone-v-in-digital.html Theory predicts: the neutral surface should render 101 RGB if exposed according to the spot-meter; next stop is 138 RGB, then comes 189 RGB, difference between the 2 is almost exactly the +2. I find this unlikely if the camera was just flubbing the flash. Last edited by jeffkrol; 02-15-2009 at 09:43 AM. | |
Bookmarks |
Tags - Make this thread easier to find by adding keywords to it! |
camera, dslr, flash, photography |
Thread Tools | Search this Thread |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Is Flash Sync Speed limited by the body or flash? | Reportage | Troubleshooting and Beginner Help | 16 | 09-16-2010 06:18 AM |
Ghosting - Due to UV? | ManhattanProject | Pentax SLR Lens Discussion | 5 | 08-11-2010 03:00 PM |
Pentax is due for a new body soon... | jct us101 | Pentax News and Rumors | 90 | 07-31-2010 02:28 PM |
When is The Next Lens Roadmap Due Out ? | wll | Pentax News and Rumors | 1 | 05-22-2009 03:04 AM |
Due in 2.5 weeks | KrisK10D | Post Your Photos! | 9 | 04-19-2008 12:02 PM |
