Originally posted by dlacouture WheresWaldo : please check with the k20, but with the k10, it's better to shoot DNG (card space apart), then import and convert it to DNG (!) via Adobe CR converter...
Sounds dumb, but you can gain some extra pixels via DNGRecoverEdges this way...
There are two fields in the DNG spec that address extra pixels
DefaultCropOrigin and
DefaultCropSize they are both used as, according to Adobe:
Quote: Raw images often store extra pixels around the edges of the final image. These extra pixels help prevent interpolation artifacts near the edges of the final image.
DefaultCropOrigin specifies the origin of the final image area, in raw image coordinates (i.e., before the DefaultScale has been applied), relative to the top-left corner of the ActiveArea rectangle.
So if there is a difference in pixel area I would be suprised if it is significant. Either way you do not do yourself a disservice if you choose PEF or DNG as your default. I will also do a little experiment to see if this difference exists in the K20 and/or in converted PEFs.
