02-11-2009, 01:41 AM   #1
Catch in focus + K20D + M42
Hi all!
My first post here so be gentle
I'm trying to get the cath in focus feature to work on my K20D but it just won't. I have enabled the C.function 34 (I think) cath in focus, as well as C.function which allow me to use lenses without an "A" setting.
I put the camera in AF.S and I get the auto focus confirmation but if I manually make the image OOF and press the shutter release button it just takes the photo, it's not waiting until it's in focus.
Am I doing something wrong?
02-11-2009, 11:47 AM   #2
Since it's manual lens, AF won't work. You should put it on MF, the AF confirmation from the camera is not correct when using manual lens. just use your eyes to focus it or change the focus screen to a split focus screen for much accurate focus.
02-11-2009, 01:29 PM   #3
bnishanth's Avatar
QuoteOriginally posted by Overhard Quote
Are you making sure the focus confirmation (Green hexagon) does not exist to indicate that the image is OOF before clicking ? Since you get a confirmation and then manually make the image OOF, and go on to click, I guess, it still assumes image is in focus from your previous focus check.
Just my guess and also not sure if it's any different from K10 as thats what I have.
QuoteOriginally posted by winglik Quote
OP wants to know "catch in focus" and not focus assist in Manual. Also focus confirmation works for me in K10D, and I often use it.
Cheers
Nish
02-11-2009, 02:22 PM   #4
Aluminum foil trick
...the AF confirmation from the camera is not correct when using manual lens. just use your eyes to focus it or change the focus screen to a split focus screen for much accurate focus.
The AF confirmation does work on my K10D. I don't think the K20D is different.
Back to the OP's question of "catch in focus," I assume that this is the same as "focus trap": the shutter fires ONLY when the image is in focus.
The "focus trap" works only when the electrical contacts on the lens mount are shorted. Maybe only some, not all, of them needs to be shorted. But who cares.
Some M42 lenses have a large flange to cover the electrical contacts on the camera body's lens mount, and the flange is bare metal. This will shorts the contacts and "focus trap" will work.
Some M42 lenses have narrow flange, or the flange is painted. The contacts thus are not shorted.
If the flange covers the contacts and is painted, you can scrape the paint off.
If the flange is too small to cover the contacts, use a piece of aluminum foil between the lens and the body to cover the contacts.
camera, dslr, focus, focus k20d, k20d, photography
How to use Trap-focus or Catch-in focus eurostar Pentax DSLR and Camera Articles 34 07-22-2017 08:29 PM
Pentax K20D & M42 Lenses Infinity Focus Question kopimorning Pentax SLR Lens Discussion 4 07-17-2010 05:56 PM
Intermittently working "Catch-in-focus" while using m42 screwmount lens shuttervox Pentax DSLR Discussion 1 08-06-2009 07:55 PM
K20D: Focus Confirmation & SR with M42 lenses? Jim Royal Pentax DSLR Discussion 10 04-14-2009 10:21 AM
K20D - Catch in focus - a backward step Arpe Pentax DSLR Discussion 10 04-09-2008 06:48 PM
All times are GMT -7. The time now is 03:14 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
